New Boiler - pipes keep leaking...help
Discussion in 'Boiler Forum' started by benj, Oct 4, 2010.
  1. benj
    benj New Member
    Dec 31, 2009
    Tacoma, WA
    I had a boiler installed almost a year ago. The house is nearly 80 years old and this is the first boiler replacement...cast iron in the old one rusted through and cracked.
    The new one was installed with 1 1/4" black metal pipe. A lot of off the shelf nipples were used and a bunch of pipes were cut and threaded on site. They used a blue pipe dope, not sure which one, but I've had many leaks since the installation. The company who installed it has been back 4 or 5 times, several times taking half the new pipes apart and putting them back together with bigger wrenches. The last couple times they've used teflon tape and pipe dope but still some are leaking.
    The water pressure is about 18 pounds.
    Any suggestions?
  2. MAoilTech
    MAoilTech New Member
    Nov 24, 2009
    Oil Tech,HVAC
    MA
    Sound like the pipe thread die was no good or they do not know how to thread pipe did they use pre-treaded pipe at all if so are they leaking too?
  4. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    Something is wrong if they develop leaks after install, especially in numerous joints.
    I used the blue dope because it is more "gasket like" and more forgiving. Now I use regular grey/white dope along with tape. I have since learned to do it this way and just about never get leaks.
    If they are pros then I would guess they should know how to properly dope up the threads. It may be as mentioned that the threads where bad, either on the ones they made on site or the premade....lots of pipe and fittings from CHINA.
    Got any pics?
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Keep calling them back to fix it. You paid for it.
Similar Threads: Boiler pipes
Boiler Forum Boiler pipes and electric baseboard heat Jun 5, 2013
Boiler Forum Boiler Pipes hot when heat has been off for months? Boiler used for DHW. Nov 16, 2011
Boiler Forum Insulating BoilerCopper Pipes Feb 4, 2010
Boiler Forum Weil McClain cga6pidn boiler Friday at 1:49 PM
Boiler Forum An American Standard Gas boiler Mar 13, 2017
