new bathroom taps - smell of bad eggs-help!
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chrisbrankin, Dec 2, 2006.
  1. chrisbrankin
    chrisbrankin New Member
    Dec 1, 2006
    hi
    i had a new bathroom installed a few weeks ago, complete renovation, new pipes etc.
    i now get a strong bed egg smell when the hot water SINK tap is turned on after not using for an hour or so (ONLY the sink, bath next to it has no problems!?*)
    the smell lasts for about 20 seconds and then clears
    there is a much less noticeable smell from the cold sink tap
    it is defiinitely not a drain problem
    if i leave the taps just dripping overnight - no smell in the morning
    i hope someone can help because i have run out of ideas and so has everyone else!
    thanks in advance for any suggestions
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Do you know what type of water pipe your house is plumbed with and did they use the same type / kind of pipe for the new bathroom?
  4. chrisbrankin
    Dec 1, 2006
    hi cass
    thanks for reply
    they plumbed new copper pipe onto the old copper pipe, for the last metre to the taps they used white braided plastic with chrome end pieces to connect to the copper and tap.
  5. Terry
    Aug 17, 2004
    If it's the lav faucet with flex supplies, consider changing them.
    I know someone that after replacing a kitchen faucet had a taste problem. Before the faucet had been replaced, they had been drinking from it all the time. They gave up on it for some time though, buying bottled water at the grocery store. It was the only faucet in the house that had bad taste.
    Changed out the supplies, and the water was fine again.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Im with Terry. Replace the supply lines with braded stainless steel ones.
Similar Threads: bathroom taps
Plumbing Forum, Professional & DIY Advice Taps in the bathroom Jul 31, 2006
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Today at 11:20 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink drain gurgles going down. Sunday at 1:49 PM
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Sunday at 10:01 AM
Plumbing Forum, Professional & DIY Advice Bathroom planning advice (venting questions primarily) Feb 12, 2017
