I am running a few new circuits in my unfinished basement. I am planning 8 or 9 duplex on a 20 amp breaker and 12/2 wire. I plan to put a gfci duplex on the first outlet and feed off the load for the remaining downstream. I want the outlets on the wall so I need to run conduit from ceiling down the wall.
Question 1: what size pipe do i need in order to run 5 ft down with 2 12/2 w/ground cables?
Question 2: what is used at the top of the pipe to protect the cable? I found plastic female treaded bushings would these be sufficient?
That would be one scenario.
Or would I be better to put junction boxes at the ceiling for every drop? forgot to mention i am planning emt for conduit
