New Baseboard Heater install
Discussion in 'Electrical Forum discussion & Blog' started by 98ZJUSMC, Nov 29, 2010.
  1. 98ZJUSMC
    98ZJUSMC Member
    Mar 9, 2010
    Tunnel Hill, Ill
    Hey!
    This is more an electrical issue so, I'll post it here. I am installing a 240V 500 Watt Cadet baseboard heater in a bedroom I am remodeling. I ran the NMB from a single pole 20A double breaker (more on that in a minute) to a receptacle box on the wall of the bedroom where the thermostat will go, then to the heater. I wired the thermostat box direct just to make sure the heater is working. I get power on both legs at the thermostat box and at the heater itself. It's not working at all. No heat, whatsoever.
    I realize that I need to install a double pole breaker for the final install so both legs will trip together. The single pole is just a temporary to make sure there are no problems along the run.
    My assumption is the heater is bad. Anyone see any other problem? I ran my Fluke Voltage Detector down the heater element of the heater and it tweeted very intermittently. I assumed it would tweet constantly. All connections have been checked and double checked.
  2. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    The 500 W heater should read (240^2)/500 = 115 ohms.
  4. 98ZJUSMC
    98ZJUSMC Member
    Mar 9, 2010
    Tunnel Hill, Ill
    Oh. I didn't check continuity. Where can i check that at the two power leads?
    It's definitely 500W
  5. Jim Port
    Jim Port Electrical Contractor
    Aug 22, 2009
    Maryland
    Can you describe the breaker again? A single pole double breaker does not make sense.
    What connections did you make at the heater?
  6. 98ZJUSMC
    98ZJUSMC Member
    Mar 9, 2010
    Tunnel Hill, Ill
    I used a 20A 2-circuit circuit breaker. There is only one buss bar clip.
  7. nukeman
    nukeman Nuclear Engineer
    Nov 20, 2009
    Nuclear Engineer
    VA
    Sounds like that is the problem (assuming it is a tandum type breaker). Single breakers normally grab onto one buss bar. In order to get 220/240V, you need to be connected to both bars. A normal breaker for this situation will grab onto both bars.
    Assuming that you have not checked the total voltage (red to black), what you are getting is 110v on each leg, but the legs are the same phase, so the actual voltage that the heater is seeing is 0v.
    Get the right breaker, and you should be in business. If it still doesn't work, check voltage at the t-stat and heater and then get the ohms on the heater itself (power OFF).
  8. 98ZJUSMC
    98ZJUSMC Member
    Mar 9, 2010
    Tunnel Hill, Ill
    Ahhhhh..... Thank you nukeman. I read this about the voltage somewhere else, but couldn't get an explanation. Or at least one I could understand. I thought.....well, I thought wrong.
    I'll go ahead and do that. I have an empty breaker above the tandem in the breaker box. I'll hook one leg up to it and simulate the two legs for test purposes.
  9. 98ZJUSMC
    98ZJUSMC Member
    Mar 9, 2010
    Tunnel Hill, Ill
    Thanks nukeman. Hooked it up that way and she be heatin'!
    Off I go to the Depot!
  10. nukeman
    Nov 20, 2009
    Nuclear Engineer
    VA
    Good deal. Glad to hear that it is now working. :)
Similar Threads: Baseboard Heater
Electrical Forum discussion & Blog Advice for wiring 2 baseboard heaters Dec 16, 2016
Electrical Forum discussion & Blog how many connections in baseboard heater? Oct 7, 2014
Electrical Forum discussion & Blog Portion of 240 Volt Circuit only Delivering 120 Volts to Baseboard Heaters Nov 23, 2013
Electrical Forum discussion & Blog Back-up baseboard heaters Oct 7, 2013
Electrical Forum discussion & Blog Wiring Multiple Wall Thermostat Controlled (Cadet) 240v Baseboard Heaters Apr 24, 2012
