New 220 4 wire stove and old 220 three wire plug
Discussion in 'Electrical Forum discussion & Blog' started by Wardsweb, Mar 17, 2008.
  1. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Exactly. And the GROUNDED circuit conductor is the neutral. The "ground" is the grounding conductor.
    Big, BIG difference.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Yea what Petey said and the green conductor can not be used here, period
  3. Wardsweb
    Wardsweb New Member
    Apr 24, 2007
    San Antonio TX
    Followup: the old wiring was removed. Good thing too, as it was aluminum. Nice new correct wire run and new recepticle installed. Like my father always told me, "there is only one way to do it...the right way."
  4. Lotus
    Lotus DIY Junior Member
    Jan 4, 2010
    Portland OR
    thanks for the clarification
    good advice - my search got to this forum because I replaced an oven - both the new and old units had the neutral "white" cable bundled with the grounding "bare copper" cable running about 10 feet to the service box - I had heard that this was out of code and that I should change the wiring to a 4-wire set from the service box - but I had also heard it was a minor, non-critical issue
    after reading this, i thought just rewiring it as before would probably be OK - I consulted with an electronics engineer friend who confirmed that, yes, sending an energized neutral into the grounding path is only very slightly risky - he did the math and said we should wire it up, apply power and test the unit with a voltmeter - sure enough, voltage between the oven frame and the kitchen sink is .7 volts
  5. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    And how much current or amperage was on this path?
    Remember it is not voltage that does harm but amperage that kills!!!!!!
    Find yourself a new electronics friend before this one gets you killed.
Similar Threads: wire stove
Electrical Forum discussion & Blog Adding Ground Wire to Kitchen Stove Jan 19, 2015
Electrical Forum discussion & Blog Stove Wire Repair Mar 6, 2011
Electrical Forum discussion & Blog Can I wire in an oven to this sub panel? Yesterday at 11:20 AM
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog What Monkey Wired this outlet?? Jan 10, 2017
