I need to check the local codes, but how critical do you think it is to neutralize the condensate from a high-efficency burner, be it a furnace, boiler, or hot water tank? One boiler I looked at said the condensate could be in the ph 3 range. I live in a townhouse - the unit's drains are pvc, but the main line is cast iron (about 20' from the drain).
As opposed to the type discussed for whole house neutralization where there is a lot of flow, here, there would be minimal flow and seasonal (a lot more in the winter! than summer).
