Neutral and Ground Bus Mixed
Discussion in 'Electrical Forum discussion & Blog' started by Todd Groendyke, Aug 22, 2013.
  1. Todd Groendyke
    Todd Groendyke New Member
    Jul 15, 2013
    Georgia
    Hello: I recently bought a 1950's house. I was examining the electrical panel and it looks like neutral and ground lines are mixed in the the neutral and ground bus. Some neutral are on the ground bus, some ground on the neutral, etc. Is there any reason for doing this? Is it a problem? Should I leave it alone or switch all the neutrals and grounds to their proper bars?
    Thanks,
    Todd
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Are you going by wire color ?
    It looks a bit mixed up to me.
    If you update it you should bring it up to code.
    Older homes did not have a safety ground.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    That looks like the service panel or I would be more correct if I stated this looks like the service disconnecting enclosure and if my assumption is correct and the two terminal bars are bonded together and to the enclosure there is no problem with the panel.
  5. Todd Groendyke
    Jul 15, 2013
    Georgia
    These photos might show it a little better. My main concern is that neutrals (white) and grounds (bare copper) seemed to be mixed on these bars. Shouldn't all the neutrals be on the neutral bar and all grounds on ground... or does it matter? Or is there a reason to mix them?
  6. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    There is NO separate neutral or ground bar in that main panel. Both bars serve BOTH purposes.
    It is FINE.
  7. Murphy625
    Murphy625 Member
    Jul 7, 2013
    Michigan
    If the house was built in the 1950's, that panel is not the original and has already been updated. Looks fairly new to me.
    I would almost go out on a limb to say that the panel was updated just to sell the home. Judging by the lack of oxidation, dust, debris, etc, I would say that panel was installed within the past 5 years.
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is a much better picture.
    It looks fine.
  9. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Hard to tell wire size on that pic, but there is a mix of 15 and 20 amp breakers yet some of the wires look to be the same size.
  10. Stuff
    Stuff Active Member
    Mar 7, 2013
    Pennsylvania
    Both bars are tied together via the factory strap so they are logically the same bar.
    Other issue is that neutrals are sharing lugs. They should be on their own. Grounding wires can share if mentioned on the panel label.
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Good point. I did notice that.
    There were spares that could have been used.
    I think it may be ok if the ground and neutral go to the same circuit.
  12. adsforpay
    adsforpay New Member
    Dec 22, 2004
    Retired-Automotive Service
    Arkansas
    This is not really related to the original question... but I couldn't help but notice... On the top row of breakers, on the left is a 30A two pole labeled "Dryer", with what looks like 10Ga wire. Which is fine, but using those wires as a size comparison, on the right end of that same row of breakers is a 40A double pole, labeled "Air Cond", with what looks to be 12Ga wire. They look like the same size wire as on all the 15A and 20A breakers. If so, those wires are not protected by a 40A breaker. Maybe the OP can confirm or deny what seems to be in the pic.
  13. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    The OP was asking about the grounds.
    You are correct "This is not really related to the original question... "
    But it is nice to keep people safe.
  14. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    What I said .
  15. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    We size the conductor by the minimum circuit amperage and the breaker by the maximum circuit amperage therefore it is possible to have #14 protected by a 40 amp breaker on any motor appliance such as AC or heat pump. The running overload that is in the compressor will protect the motor and conductors from overload. The breaker protects against ground fault and short circuits.
Similar Threads: Neutral Ground
Electrical Forum discussion & Blog Ground to neutral question, mobile home Dec 20, 2015
Electrical Forum discussion & Blog Separating Ground & Neutrals to Create Subpanel Aug 23, 2013
Electrical Forum discussion & Blog Can neutral and ground from 50A breaker be shared Apr 21, 2013
Electrical Forum discussion & Blog Odd Hot-Neutral Reverse after Ground. Feb 4, 2013
Electrical Forum discussion & Blog Subpanel neutral/ground isolation Jan 14, 2012
