Neo Angle Shower Base Leveling
Discussion in 'Shower & Bathtub Forum & Blog' started by jrgallant, Jan 29, 2009.
  1. jrgallant
    jrgallant New Member
    Apr 5, 2008
    Hello everyone. I've got a question that hopefully someone can answer for me. I'm installing a neo angle shower in my new bathroom. My subfloor was unlevel, so I built some forms and poured some self leveling cement to level the shower area. After the first pour, it was still a little out of level so I did a second pour. The area is now level; however, when I place my shower base on it, it still rocks a little which I'm concerned about. Especially around the drain area. The only thing I can assume now is that the shower base itself isn't completely true. What I've been thinking is perhaps I can lay some kind of a mortar bed, connect my drain assembly and just set the base in place level and let the bed dry. My question is would this be okay and are there any suggestions for a product to use for this. I was thinking a thinset mortar but I'd be glad to hear if someone else has another suggestion.
    Thanks in advance for your advice everyone.
  2. jadnashua
    SLC requires lath on a wood subfloor and primer. Did you use those?
    What often is used is something like Structolite or deck mud. Deck mud is a sandy mix of 4/1 sand to portland cement...the same stuff as used in making a traditional shower pan. The mix can be from 3-5 parts sand. You'd throw some down then mush it into the mix, leveling it carefully then leave it alone for awhile until things set up.
Similar Threads: Angle Shower
Shower & Bathtub Forum & Blog Do all neo-angle showers have the same relative dimensions? Feb 27, 2017
Shower & Bathtub Forum & Blog Basement Bathroom Remodel with neo-angle shower pan Apr 6, 2014
Shower & Bathtub Forum & Blog Polystyrene neo-angle shower Nov 18, 2013
Shower & Bathtub Forum & Blog Basco Enclosure for 36 inch Neo Angle Shower Nov 8, 2013
Shower & Bathtub Forum & Blog Neo angle shower base...or, doorless shower?? Aug 21, 2013
