Needed: Wall Mount Toilet Advice
Discussion in 'Toilet Forum discussions' started by ThomasD., Dec 3, 2011.
  1. ThomasD.
    ThomasD. New Member
    Dec 3, 2011
    Fairbanks, Alaska
    Great forum here, my compliments to all involved. I am in the process of remodeling / constructing a 5-room "Inn" (my wife doesn't like the sound of "B&B"). Each room will have a it's own full bath w/ separate shower. The toilet / shower area will be fully tiled & the floor sloped into the shower for easy access / cleaning. We want a fairly "modern & contemporary" style and because of the sloped floor, a wall mount toilet would be ideal. So, after much internet research, I just haven't found any real useful reviews of contemporary wall mount toilets. I have no problem with the "rough-in" frames or additional structural framing, just need good, solid advice on which toilet / rough-in frame combination will work best and efficiently for flushing and cleaning. Because of the hospitality nature of our project, they will be cleaned daily but good flushing / wash down is still essential. We currently have 3 of the Kohler "Cimmaron" toilets which at the time were highly recommended. We have found them to be some of the most poorly flushing / cleaning toilets ever. We can't afford to make that mistake again with wall mount fixtures. Any and all advice from Terry and everyone else on this forum would be much appreciated.
  2. jimbo
    jimbo Plumber
    If you want wall mount, I might suggest a tank-type toilet, such as the American Standard Glenwall, pressure assisted. The tank type give you less of a 'commercial' feel to the bathroom. The pressure assisted works well. If you went wall mount with a flushometer, you have to plan that well in advance, because you need a 1" water supply all the way, and you would have to plan the entire water supply system to the building to accomodate 5 bathrooms + I assume an owners apartment. I do like the idea of the floor you plan, but realize that must be a waterPROOF floor all the way. Not enough to just throw down extra tile. Easy to do when you plan on it from the get-go.
  4. hj
    FIVE flushometer toilets would need MORE than "a 1 inch line all the way", so the tank type is all they need, or want. I use J.R.Smith carriers, but they are all about the same quality.
  5. ThomasD.
    ThomasD. New Member
    Dec 3, 2011
    Fairbanks, Alaska
    Thanks for the replies. I was thinking more along the lines of the Toto or Duravit style wall mount toilets with recessed tank, unless there are issues with them.
  6. jadnashua
    Personally, I don't particularly like pressure assisted toilets, so I would go with a tank type as well. If you can provide the internal wall space for the tank and the access panel, that may be the way to go. I think that the Toto Aquia is available as a wall-hung.
  7. ThomasD.
    ThomasD. New Member
    Dec 3, 2011
    Fairbanks, Alaska
    Ok. I've heard good things on this forum about the floor mounted version of the Aquia, but nothing about the wall mounted version. Also, any information about which rough-in frame is preferred?
  8. jimbo
    jimbo Plumber
    Now we get to the nitty gritty. Looks like the Aquia wall hung with in-wall tank and carrier is a very nice unit, and about $1000. But any wall hung with carrier is going to be in that neighborhood.. hows you budget???
  9. ThomasD.
    ThomasD. New Member
    Dec 3, 2011
    Fairbanks, Alaska
    Budget????? Hopefully, for a semi-profitable endeavor such as a our proposed business, the return will eventually outweigh the initial cost. Quality, style and function still trump economy in my mind, but if all four were available in one unit......... Anyway, the "Cimarron" cost saving approach didn't work well. I'll pay up front for true form & function.
Similar Threads: Needed Wall
Toilet Forum discussions Help needed with Toilet selection and spacing from wall Jun 5, 2013
Toilet Forum discussions Parts needed for Duravit Wall Hung Toilet install? Mar 26, 2010
Toilet Forum discussions Wallmount carrier 'accessories' needed May 31, 2008
Toilet Forum discussions Wall hung toilet needed Mar 16, 2007
Toilet Forum discussions Parts needed for TOTO CST244EF#01 Entrada installation? Dec 13, 2016
