Capt John L
Ok. So I can fix cars, fishing poles and lawn mowers but I don't know anything much about submersible water pumps.
Here's my problem. I live in the country and made it mostly unscathed by Hurricane Matthew except tree broke the powerlines that run all the water and two houses on our farm and the neighbor.
It will be forever before they get our power on.
I want to run well with generator. THERE ARE NO MORE 4 PRONG TWIST LOCK PLUGS in North Florida and South Georgia.
We ran two 120v hots to the two power legs of where they are at the disconnect in theory giving us 240v.
The pump started and ran pressure up fast like it should. BUT. it kept running. The pressure switch did not disengage when it hit 60psi like it normally does.
Tried adding a ground wire to the same area. Same result.
Pressure switch is less that 1 year old.
What can I do to fix this. Please help this mostly broken down old Marine/Cop
