Need Toilet with 14 inch rim height
Discussion in 'Toilet Forum discussions' started by GreenTree, Nov 1, 2009.
  1. GreenTree
    GreenTree New Member
    Jun 18, 2008
    Wisconsin
    The only one I can find is the American Standard, Cadet Elongated Pressure-Assisted Toilet Model # 2333.100,
    Bowl 3099.016, Tank 4098.1000
    I'm not sure the pressure assist is the best choice.
    Please help me find another Toilet with 14 inch rim height.
    The low rim height is needed because we will add a toilet lift which raises the height by 4 inches. The toilet is for a short person whose feet won't reach the floor unless the total height is 18 inches, or less.
    Thanks for any help you can offer.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Maybe I'm missing something- you say a short person. An ADA height toilet with seat is at 17-1/2". A 14" rim height with a 4" lift would put it at 18". Either of these are better fit for a taller person.
    A typical non-ADA rim height is around 15-1/4".
  4. GreenTree
    Jun 18, 2008
    Wisconsin
    Thanks for asking for a clarification.
    The 4 inch lift is a motorized seat that raises a disabled person up off the toilet.
    Have you come across any toilets with a 14 inch rim height?
    Is there a web site that would likely list them?
  5. hj
    toilet
    The first question that comes to mind, is that since the standard toilet is about 15" high, WHY would ANY company spend the time and costs to make even a SINGLE toilet 14" high when the worldwide demand for it might be exactly ONE, namely you. I doubt that you will find anything like you need.
  6. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    14 Inch High Toilet
    What you could do is to use a wall hung toilet and put the rim where you want it, :)
  7. hj
    toilet
    Would a 10" high children's toilet, such as Crane's 3-210, work? The elongated bowl IS somewhat smaller than a standard one, but the height seems to be a factor.
  8. FloridaOrange
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I was thinking a children's toilet as well, just wasn't sure on what the "lift" mounted to.
  9. Terry
    Aug 17, 2004
    Most standard height bowls are 14.5" high
  10. gwantz
    gwantz New Member
    Sep 23, 2011
    California
    14 inch toilet height
    A 14 inch toilet height is also required by the ADA for school children from age 6-12 years old. I have contacted
    American Standard 2 years ago about this, however, they did not care to listen. They said that I would have to appeal to have
    the State and change the code. (they did not want to get involved)
  11. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I sure don't see the problem, but maybe I'm missing something. You want a toilet that has a 14" rim height. A standard toilet is 14-5/8". I find in hard to believe that 5/8" additional height will make any real difference in the addition of the motorized lift.
Similar Threads: Need Toilet
Toilet Forum discussions Need a short toilet base (front) Feb 13, 2017
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Need Advice on Toto Toilet and Washlet Nov 10, 2016
