Need to replace copper drain pipes in Basement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by smb, Mar 30, 2014.
  1. smb
    smb New Member
    Mar 30, 2014
    New Hampshire
    My house was built in 1960... I have all copper drain pipes with cast iron fittings... the stack is starting to corrode to the point where I have a hole the size of a dime at the top....thinking rather than just cutting out that piece and replacing it...I should just replace it all.....toilet, 2 sinks and a bathtub...in looking at the drains for the sinks and tub they are back pitched. I am relatively handy and have been researching doing this job for some time...so if someone could give me a starting point and direction I'd appreciate it.. going to go all pvc...
    20140330_162537.jpg 20140330_162518.jpg 20140330_162610.jpg ..
  2. jadnashua
    There are a few places that require metal drain pipes, so before you try to convert, you need to verify what is allowed. Then, while you'll have to sign your life away, recycle the copper, it's worth a lot of money per pound, it will help pay for a bunch of your new materials! Since there are lots of thieves stealing copper out of buildings, you have to prove to them it's actually yours to recycle.
    Keep in mind that what was to code in 1960, may no longer be, and you may not be able to just try to replicate what you have in say PVC. When you make significant changes like replacing all of the pipes, whatever is done must be to current code. You need to check which code your locale uses, as not all places use the same one, some are more lenient than others as to what is allowed and how to do it.
    It looks like at least that CI drain line is still in decent shape, so the conversion from copper to plastic would start with removing the copper in the hub. Then, you'd measure the cleaned up opening after removing all of the lead and oakum, pick up the proper rubber donut seal, and insert it and the pvc in and start building up (easier than working from the top down). Since you won't get it all done in a day, you'd want to pick up some banded couplers (you'd need the right one to convert between pvc and copper) so you could reconnect things as you go.
    This may not be a DIY'er friendly job, as the plastic pipe has thicker walls, and you may need to make the holes larger as you go through things, plus, it will take awhile, and I assume you plan to live there while it is happening. Plus, as mentioned, the code changes that have occurred in the last 50+ years.
    Without seeing the entire setup, there is no way to tell whether you can just duplicate what's there, and what's there may not be the most expedient way to replace things. There are likely more fittings for pvc than there were for copper, and you'd have more choices.
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Where is the hole with respect to your photos?
  5. smb
    smb New Member
    Mar 30, 2014
    New Hampshire
    vent
    looks like the vent pipe is also copper, should i replace that as well or should it be ok since no water going through it?
Similar Threads: Need replace
Plumbing Forum, Professional & DIY Advice Do I Need To Replace This Pipe Soon? Mar 15, 2017
Plumbing Forum, Professional & DIY Advice Need to replace part of cast iron vent stack in my attic bathroom Dec 3, 2016
Plumbing Forum, Professional & DIY Advice Kohler Cygnet faucet handle -1980's handle & assembly that needs to be replaced Oct 1, 2016
Plumbing Forum, Professional & DIY Advice Need advice. replair or replace shower/tub hardware. Now? Later? not at all? Sep 25, 2016
Plumbing Forum, Professional & DIY Advice Symmons Temptrol, Does shower cartridge/diverter need to be replaced? Jan 27, 2016
