Need to Repair Lead Closet Flange but the Pipe is Crooked!
Discussion in 'Toilet Forum discussions' started by bw4725, Aug 21, 2013.
  1. bw4725
    bw4725 New Member
    Aug 21, 2013
    qc
    ]My lead over brass closet flange needs repair. There is only about 5/16" of lead remaining in the front of the flange:
    I was going to cut off the lead part and join the copper pipe to ABS with a flexible coupling. I then noticed that the pipe is very crooked. It is about 5 or 6 degrees off plumb. How much leeway does a flexible coupling allow? If the ABS is aligned with the copper, one side of the flange will be lifted by 3/4" . The pipes might not even align if the lead section is hiding even more crookedness. Even worse, I think the pipe might be smaller that typical 3" pipe. I calculated 3.14" which is too small for the coupling I bought. (Pro-Connect 56-33)
    I found a lead repair part that might work:
    http://www.renodepot.com/en/sleeve-lead-toilet-sleeve-04825002
    Does anyone have any tips on how to use this part. I figure that pounding this sleeve cold into the old one would be insufficient.
  2. bw4725
    bw4725 New Member
    Aug 21, 2013
    qc
    So I talked to the people at the store about the lead sleeve. One sales clerk said that you just have to jam it into the old one and the deforming lead will make a gas tight seal. Another clerk said that you need to solder the two together. Would tin/lead solder work? I would think that the solder would be harder than the lead and might cause tearing when I try to peen it down.
Similar Threads: Need Repair
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions NEED HELP: repairing/replacing pan outlet/connector leak. May 10, 2014
Toilet Forum discussions Vintage Crane Siwelclo 1935 toilet repair - need help Dec 9, 2013
Toilet Forum discussions Moderate Floor Damage - Needs Repair? Sep 30, 2013
Toilet Forum discussions Need help with repair of 40 year old toilet Feb 22, 2009
