EivlEvo
Greetings all... I'm a longtime ghoster on this site, and now being a homeowner have some questions.
The house we bought has a newly remodeled kitchen (I believe mostly done by small schoolchildren)... we knew this going in, and I have a strong DIY skillset.
One of the first things I went to do was install a garbage disposal. Upon assessing the undersink PVC plumbing (which was leaking badly due to poor installation) and removing said PVC, the undermount sink actually fell out. I re-epoxied and sealed this up, and now am back to the disposal. The waste outlet on the disposal sits MAYBE 1/4" above the drain (which runs horizontally into the wall to the right approximately 4 feet. It is making the correct 1/4" grade, but it connects into the cast piping in the wall with a "normal tee" (not sure if this should be a sani or not?). This tee regardless is what I need to lower by an inch or two so that I can install our disposal.
2 Questions.
1. How should I go about this? Should I first support the vertical piping, get the angle grinder/sawzall into the pipe, and remove the tee. Once that's out, insert a CI (or should I use ABS?) sanitary tee using the steel banded AND stainless wrapped no-hub couplings on the top and bottom? Or is this just asking for trouble? (Worth noting that the house is a split level and this would be in the lower floor)
2. Do disposals have higher waste outlets? I feel like ours is pretty high on the disposal (wasteking legend 8000)... and I have it on the higher sink basin. Either way... it's worth knowing the proper way to do such a thing would be.
Thanks, sorry for the essay.
2 Questions.
