Need to find a wrench for this
Discussion in 'Drain Cleaning' started by Melissa2007B, Mar 5, 2009.
  1. Melissa2007B
    Melissa2007B Member
    Jun 15, 2007
    Denver, CO
    We have this main line cleanout cap in the driveway and it's an inverted square. Dont they make a wrench that will open this?
    [​IMG]
  2. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    We use two large screw drivers , stick each one in opposite corners crossing the blades and twist. There is a manufacture that makes square head tools for the counter sunk plug as well.
    [​IMG]
  4. Melissa2007B
    Melissa2007B Member
    Jun 15, 2007
    Denver, CO
    Thanks. Any idea what they call that tool?
  5. SewerRatz
    Nov 20, 2008
    Chicago, IL
  6. Melissa2007B
    Melissa2007B Member
    Jun 15, 2007
    Denver, CO
  7. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    hammer and small cold chisel
    I always thought you were supposed to use a hammer and small chisel to open those up, slightly tapping in the right direction along the outer threads usually works ...
    but that is a neat tool....
  8. SewerRatz
    Nov 20, 2008
    Chicago, IL
    You know me, I must have new tools. I have a few I made for certain applications. One day I will take some pictures of them and post them up.
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Being in the trade I have that tool as well.
    Problem is every time I find one of those some Idiot new construction plumber has always set the cleanout so deep in the floor that the tool won't reach it... :mad:
    If I was on Mellisa's situation where it's a one time use I would just measure the size of the square and buy a pipe plug with the same size square and turn it with a pipe wrench.
    Save a bit o cash...
    [​IMG]
  10. SewerRatz
    Nov 20, 2008
    Chicago, IL
    The tool is only 12 bucks. I have a tool like that but the squares are extended a foot for the clean outs that are below the floor. I will take a picture once I pick up a new digital camera.
  11. Jay Mpls
    Jay Mpls Master plumber
    Sep 29, 2008
    Master Plumber /Sewer rat
    Minneapolis
    I use a pipe wrench,channel locks or hammer and cold chisel and have a supply of 4" pvc flush plugs and 'real tite' plugs ready to go.
  12. Melissa2007B
    Melissa2007B Member
    Jun 15, 2007
    Denver, CO
    You cant have TOO MANY tools. :D
  13. hj
    tool
    A section of the proper size square tubing from HD or Ace hardware will work also. That's assuming ANYTHING will turn it. In most cases it will have to be cut out and replaced.
  14. Melissa2007B
    Melissa2007B Member
    Jun 15, 2007
    Denver, CO
    No, we keep it loose so it can be turned. We've had so many problems with the plumbing here....
  15. hj
    loose
    Loose is good, but even if it were not, it would not be a "plumbing problem" it would just be the normal situation. As my dad always said, "they make those plugs thin so we can chop them out easier."
  16. Melissa2007B
    Melissa2007B Member
    Jun 15, 2007
    Denver, CO
    I was gonna look down there and see if I could tell anything, but I'm REALLY glad that I got the right plumber over here instead. This was a terrible mess that none of the rooter people could have ever solved:
    http://www.terrylove.com/forums/showthread.php?t=27371
Similar Threads: Need find
Drain Cleaning Need ideas on unclogging between tub and main septic line. Jan 16, 2015
Drain Cleaning Need Help Identifying How To Clear A Section Of 4" Sewer Line In My Basement Sep 29, 2012
Drain Cleaning Bio-Clean "how to" instructions needed, please! Mar 30, 2012
Drain Cleaning I don't want to kick out my tenant... main line needs repair Feb 26, 2012
Drain Cleaning $10K in damage so far...HELP NEEDED PLEASE! Jul 19, 2011
