Need to break vacum in water softener drain line
Discussion in 'Water Softener Forum, Questions and Answers' started by smithwd, Oct 16, 2011.
  1. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    have a 1/2" pex drain line running outside as I can't run it into my septic system anymore.......I installed a Watts N36 vacuum breaker at the highest point to allow all the water to drain and eliminate any freezing problems. During regeneration the valve disk flutters making a moaning/groaning sound. Any ideas? Drain is under house pressure when it runs....
  2. Gary Slusser
    Retired
    The 1/2" PEX has a smaller ID than 1/2" PE drain line so you are reducing flow to drain and that is not a good idea because the gpm flow rate is already flow controlled in the control valve. Most residential softners require a 1/2" ID drain as a minimum. If you have to or want to use PEX, use 3/4".
    That may or may not be the cause of the abnormal noise you hear.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    How long is the run of pex? Where along the run is this vacuum breaker? Change out the rest of the run after the vacuum breaker to larger pipe provided you can have enough standpipe to assure it cannot backup and overflow. An AAV on the bigger drain pipe should be quieter.
  5. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    What it looks like
    6' from the softener to the vacuum break which is along the ceiling so make it a 3' rise.....then it runs downhill to a dry well outside of the house less than 30 feet......the drain hose from the softener is 1/2" matchs the pex........the vacuum breaker is attached via a tee with 3/4 pex. connection running vertically
  6. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    Possible answer from another forum
    A response to another similar question about drains freezing from water held by a vacuum lock stated that if the end of the drain line is open then the water should drain back to the highest point in the drain line which is in my floor joists.......so my vacuum breaker was actually a waste of money.............does this make sense??
  7. Gary Slusser
    Retired
    Yes.
    No breaker is needed as long as water can flow freely out the end of the drain line, which means no freezing of a pool of water on the end of the drain line.
  8. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    Case closed
    Thanx for the help.........so much for dealing with the pros at my plumbing supply house. at least my money will keep them in business..............
  9. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    case reopened
    i think I still need a vacuum break as the drain line drips with the leftover water....i tested the other side of the loop to see if the tank valves were leaking and no dripping..so I'm guessing there is still some water left in the drain that is held by a vacuum and is slowly weeping out.....the side that i tested had no vacuum and drained completely. so i'm back looking for some type of vacuum breaker other then the n36 unit i tried....
  10. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Replace the outside piping with larger pipe and deploy an air-gap. That is how I deal with mine.
    [​IMG]
  11. Gary Slusser
    Retired
    Unless you have a leak, the dripping will quit shortly after regneration.
  12. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    With 1/2 pex, the capillary action could trap water unless it was perfectly pitched. A larger pipe such as 1 - 1/2" or 2" PVC properly pitched should drain even without an AAV. Of course, when running buried pipe, ground swelling or settling can create sags or humps that trap water. The larger the pipe the less affected they are by sags or humps.
  13. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    no leaks
    i tested for leaks at the softeners just to make sure.........i still think that some water is left in the drain near the high point and that's my source of dripping until its gone.........I haven't found too many Vacuum breakers like the watts N36 that might fit................................
    before the drain exits the house it has a 15' flat run along the wall........the high point is 3 feet above that.....possible some water left in that..
    is there a "breather" available that would add air but not allow the water to leak out...say install it on the top of a tee??
  14. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    bright idea....
    between the highest point of the drain and the exit level i'll put a trap .(extend the drain line to the floor then bring it back up.....that should collect any exess water from the high point...
  15. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    With a contiguous pipe without an air gap, it would be like holding your finger on the top of a straw. The vacuum and capillary action conspire to keep the water in the straw.
  16. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    final resolution
    I think I'll use the tee at the highest point of the drain and run the third leg into the washing machine drain as a breather...........if the outside line freezes then it goes into the septic as a backup...voila.....
  17. rjh2o
    rjh2o Member
    May 10, 2011
    Michigan
    The vacuum breaker is not necessary as stated by others. The vacuum breaker is actually creating back pressure on the softener valve when it is regenerating causing the NOISE you mentioned.
    RJ
  18. smithwd
    smithwd New Member
    Dec 14, 2009
    retired
    Marlborough, CT
    Valve noise
    The noise was coming from the seat vibrating in the vacuum breaker...................
    someone said raise the water softener higher then the outlet......but that won't happen...........
Similar Threads: Need break
Water Softener Forum, Questions and Answers I need a softener help me pick Yesterday at 6:52 AM
Water Softener Forum, Questions and Answers I need a professional’s guidance in replacing my water softener. Feb 13, 2017
Water Softener Forum, Questions and Answers Softener, Just need some advice and help... Feb 9, 2017
Water Softener Forum, Questions and Answers HELP NEEDED! Update whole-house water filtration system (well water) Feb 6, 2017
Water Softener Forum, Questions and Answers Well water test results back need advice for new setup Feb 1, 2017
