I'm trying to find an adapter for either my sink faucet or my tub so I can connect a garden hose to one of them. I have a large 7'x18' shower/tub "wet room" and would like to be able to use hot water to hose the wet room down while cleaning it.
The sink faucet is a Delta Victorian wide handle. The spout is 3/4" diameter has a male threaded end that is 3/4"-27 thread.
The tub faucet is a Delta Victorian Roman Tub wide handle. The spout has a male threaded end but the thread size is not documented anywhere. I even called Delta and they couldn't tell me the thread size. The spout is right at 1" diameter so I imagine it has a 1" thread of some sort.
Here are some of the adapters I have looked at.
Not sure if the 3/4" FNPT would fit the sink faucet, but this would be perfect if it fit......
http://www.zoro.com/i/G2397516/?utm...9M5xORmcEI6kI-qrvmZb16KOzG258k8aTwBoCNv3w_wcB
With a 9/16" ID rubber fitting, I think I might could squeeze this over the 3/4" sink spout. Might be a tight fit though. Would be great if I could find one of these that would fit over the 1" tub spout. With this adapter I wouldn't have to worry about doping up the threads on the faucet.
Another option I am considering is to tap into the existing PVC and just put in a hose bib, maybe under the sink. I have seen several PVC hose bibs. This would be a little less convenient and quite a bit more expensive.
Any suggestions would be appreciated.
Phil
Phil
