Need suggestions regarding Systems for Iron and Manganese Problem in Well Water.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by BillF, May 12, 2012.
  1. BillF
    BillF New Member
    May 12, 2012
    Louisiana
    I am in dire need of a a system for the removal of Iron 5.4 PPM and Manganese .52 PPM in my well water, The Ph and Hardness are just fine at7.6 and 9 grains respectively. I have been researching several systems for my problem, and not really sure what to believe or what is the best solution from all of the info that I've recieved.
    I have been considering a Terminox Iron and Manganese filter from Budget H2O, a Mangox filter with a preoxidizer such as chlorine from The Clean Water Store, and just recently a Manganese green sand filter from Excel Water.
    Do any of you have any history or experience with any of these companies or systems and/or do any of you have any formidable solutions?
    TIA
    Bill
Similar Threads: Need suggestions
Pumps and Tanks Well Forum & Blog. Water is life. New well drilled, need suggestions on finishing Dec 20, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure not holding. Suggestions needed Sep 26, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Need suggestions on sewage ejection pump for in-law suite in basement May 12, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Help-Need Input, Suggestions on Well Tank/Press Switch setup Mar 5, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Well and Cycle stop valve suggestions needed Dec 16, 2006
