Need "special" toilet
Discussion in 'Toilet Forum discussions' started by macdebbie, Sep 5, 2004.
  1. macdebbie
    macdebbie New Member
    Sep 5, 2004
    We live in an old house (1795) which was converted from one large house to 2 "half-houses" in the late 1980s.
    We were in need of a new toilet a couple of years ago for our upstairs bath, hired a plumber who looked at the bathroom, measured, ordered the toilet, and installed it.
    I was horrified when I came home to find that he had cut away a section of our heating unit (baseboard - forced hot water) which was behind the toilet to fit the new unit. He told my husband it was the only way to make the toilet fit.
    We have since adpoted a new kitten, and this is unacceptable, as the inside heating unit is exposed, and the edges of the cut baseboard are sharp. We have been stuffing towels all around the cuts to protect her, but this will not work now that cold weather is here.
    We had another plumber look at this recently, and asked if he could either shorten the heating unit, or replace the toilet (we can use this one downstairs). He said no one makes toilets with clearance like that from the wall. The base of the toilet would need to clear 3 1/2" from the wall, as that is the depth of the baseboard heating unit.
    I know it is not ideal to have a heating unit behind a toilet, but other than ripping up the entire bathroom floor (old wide pine) to redo the pipes - a very expensive job, we are trying to just find a toilet that sticks out enough like our old one did to allow us to use the same footprint, and just replace the cut baseboard with a new one.
    Does anyone know if there are any toilets on the market that would fit the bill?
  2. jdkimes
    jdkimes Engineer
    Engineer
    Littleton, CO
    Why don't you just get rid of the baseboard heater close off the pipe and finish up the molding and install a forced air wall heater or an overhead heat/fan/light combo like this one from Nutone. I've used them before and they work pretty well.
  4. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Bowl Base 6"
    Most bases of bowls are six inches from the wall. I'm not understanding why you don't have 3 1/2". You can go to different manufacturers sites and see their technical data sheets with measurements. Shop from Home.
  5. hj
    clearance
    I do not know what kind of toilet you have, but I do not remember seeing any, other than something like a "skirted Toto", that did not have at least 4" behind the toilet base. If you took the toilet out, and removed the baseboard unit, you could then cut it into two pieces that fit and then install end covers over them with holes for the plain copper tubing to go through between the two pieces.
Similar Threads: Need special
Toilet Forum discussions rear discharge toilet---does it need a special flange? Apr 16, 2015
Toilet Forum discussions Need a short toilet base (front) Monday at 4:30 PM
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
