Need some help with a 'tailpiece' leak
Huntington Station, NY
www.howardemerson.com
Hi all,
I actually tried to contact HJ about forwarding an email from Hansgrohe, but I think I may have figured out how to attach a file.............Hope the forum doesn't melt down now........:-]
In any case...........If the attached file can be opened, here is my problem: I have installed this just as shown on an American Standard Hexalyn vitreous porcelain sink.
It is actually not a tailpiece leak, but rather a 'flange thread leak'.
I have tightened the nut several times, ever tighter, so that the mack washer will stop the leak. Sometimes, it does not leak all day, but other times I'll catch water coming out from 'under' the nut and traveling the threads until drips down the pipe.
I used all the parts supplied and did not use any plumbers putty. Only the sealing gasket that goes under the flange. The flange certainly appears to be fitting the sink hole very cleanly.
Any tips?
Best regards,
Howard
Redwood
The leak in most cases on a pop-up assy is water leaking down the threads of the drain outlet flange between it and the mack gasket.
Coat the threads of the drain outlet flange where the mack gasket will land with teflon paste and you will not have a leak.
If the pop-up assembly is plastic throw it away and buy a brass one. This is one drain part that should be made of metal.
HJ, Redwood,
Thank you for the tip!
The flange piece and everything else is brass. It's a really high quality item all in all, but I don't understand why they don't mention using Teflon paste.
They certainly made mention of Teflon tape for the threads on the tailpipe, in the instructions.
Will do it up later this morning.
Thanks again!
Howard
Jimbo
San Diego, CA
The rubber on most mack gaskets today is too hard....it will not get all the way down into the threads , so a sealer is necessary. I rub on plumbers puttty....rub it down with my thumb so it just fills the threads....no build up. Paste is probably easier!!
Hi Jimbo,
Ya know, I was also thinking that the rubber was way too hard!
My inclination, prior to getting the paste suggestion, was to put plumber's grease, (the clear stuff) on the mack gasket where it is 'domed' so that it would insert itself more easily into the sink hole, and, therefore, perhaps, squeeze tighter around the flange threads....................
Live and learn.
Thank you.
HE
tape
There recommendation of teflon tape was on the threads of the tailpiece, not the threads of the drain fitting. And ever there I use paste, not tape.
Hi HJ,
Yes, I'm aware of their suggestion for Teflon tape on the fine threads at the end of the tailpiece, and that's what I used. It worked fine.
As per the advice you guys gave me I unloosened the nut and washer, coated the coarse threads on the flange with Teflon paste and so far so good.
Thanks again for the collective wisdom!
HE
http://www.youtube.com/watch?v=JmzrxqzINGw
