Back ground- we are a not-for-profit afordable housing group, with a deadline.
We are trying to get our development permitted. we have already proven enough water with one of our 4 wells, but the neighbours have convinced the authorities that we need lots more proof.
There is a 14gal/min well (in shale, with no liner), that is partially blocked. I can get pex down the well and probably 1 to 1&1/2" pipe down too. It was blocked at 17 ft and it seemed clear then to about 100 ft (using a counter weight from a old fashioned window). Now though the blockage is at about 20 ft.
I got a rebar tool welded to poke through blocks up to about 35 ft, but I am scared that I am just shoving something farther and farther down the well and will get stuck every fee feet all the way down.
The static level is about 15 ft.
Question- With the pump test we need to keep a steady volume about 1.25 gal/min.
I thought it would be better to try and get pipe down the well and use a jet pump, before I plug it up completely , than try and get a well pump down.
If we get the permission for the project, we will redrill the well out if we ever need to.
1. Does this seem do-able?
2. If so, what is the best way to get a constant 1.25 gal/min with this setup?
Any and all advice would be helpful. Thanks
