Need new shower/tub mixing valve
Discussion in 'Shower & Bathtub Forum & Blog' started by Scuba_Dave, Oct 26, 2009.
  1. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Well 20-20 hind-sight I would have had the mixing valve replaced when I redid the shower
    But it was not leaking at the time - 2004/5
    A new Moen cartridge a year later stopped a small drip (2005/6 ?)
    It started dripping again - off & on, now its pretty steady
    I do have a whole house filter to prevent sediment thru the lines
    I should have had the plumbing reworked & reversed the tub
    The opposite wall is a closet - plumbing is on an outswide wall
    Maybe in another 5 years I'll redo the bath again & have a plumber reverse the pipes/drain at that time :(
    So I need a new mixing valve & really don't want a low grade model from a big box store
    So what's a good brand to buy
    Bath was redone, cement board & tile
    The surround was in rough shape & leaking when we moved in
    So I didn't want to let water damage continue
    It wasn't as bad as my last house, old pic from before renovation:
    [​IMG]
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If you bought the cartridge at Low*s just go get another and return that one...it should have lasted longer than that....
  4. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I have no faith that the valve has not been worn out
    I put the whole house filter on after we bought the house
    Almost every other fixture in the house has been replaced
  5. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    As a test I shut off the HW feed to the shower
    The leak stopped
    So not only a water waste, but am energy loss too
    The old water heater rusted out shortly after we moved in
    So pretty sure rust went thru the piupes & messed up the valve
    Since then both toilets are new(er), bath & kitchen faucets too
    One toilet was getting sediment
Similar Threads: Need shower/tub
Shower & Bathtub Forum & Blog Need help with Price Pfister shower/Tub valve system (~2001 vintage) Series 02 Mar 2, 2014
Shower & Bathtub Forum & Blog Need advice on fixing Delta 600 shower/tub valve - dripping water Oct 16, 2013
Shower & Bathtub Forum & Blog What do I need...Plumbing fixtures for shower/tub Oct 10, 2013
Shower & Bathtub Forum & Blog Need to replace one-piece fiberglass shower/tub unit Mar 29, 2013
Shower & Bathtub Forum & Blog Need help finding a replacement shower/tub combo unit May 11, 2010
