sc.homeowner
we have a 240 ft well with a submersible pump which pumps ~ 8 gpm. For water conditioning I have a 30 micron WH filter to remove sand and grit, a soda ash/ chlorine injector for PH and finally a 5 micron carbon WH filter to remove the chlorine. All this has worked well except for the pressure drop after the filters make for low water pressure especially upstairs. The pressure switch is a typical 40-60 psi setup with the bladder tank inline before the carbon filter, which neither cannot easily be moved.
Is there a simple way to increase the effective pressure after the filter?
