Need instructions for Toto TSU16A fill valve
Discussion in 'Toilet Forum discussions' started by MikeMcNamee, Aug 2, 2011.
  1. MikeMcNamee
    MikeMcNamee New Member
    Aug 2, 2011
    Maryland
    Just bought a Toto TSU16A fill valve to replace the original (now discontinued) TSU08A.6. It came with no installation or adjustment instructions. I've installed many Fluidmasters, so I imagine I can get the valve into the tank with the proper end up ... but I'd like to have the adjustment instructions. A search on Toto's parts site doesn't turn up anything. Know where I can download these instructions?
  2. jadnashua
    If there's a clip on the shaft, remove it if you need to adjust the height. To release the tower for adjustment, after the clip is pulled out, you rotate it about 1/8-turn, and it will move up/down to adjust. It might be okay. Other than that, not much else.
  4. MikeMcNamee
    Aug 2, 2011
    Maryland
    Thanks ... sounds like you may be talking about the old valve, which does have a tamper-proof clip on the shaft. The replacement valve has a plastic screw projecting out of the top portion, which I presume is for adjustment.
Similar Threads: Need instructions
Toilet Forum discussions Need a short toilet base (front) Feb 13, 2017
Toilet Forum discussions Need Norris Toilet Tank Repair or replacement Feb 11, 2017
Toilet Forum discussions 24 Unit Toilet Purchase - Need Some Input (Toto/American Standard/Duravit/Caroma/Stealth) Feb 9, 2017
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Parts needed for TOTO CST244EF#01 Entrada installation? Dec 13, 2016
