today's update: pulled schrader valve, no water all air. replaced it with 30lbs of air. while I had plumbing disconnected i also disconnected pittless and blew air back thru to confirm no blockage and/or check valves. when I re-plumbed the tank in, i went ahead and i put the fittings in to move switch to the tank once I get my problem fixed, just have to pull wire and it will be a quick change. once everything was hooked up i thought all was good while system repressurized then it started bouncing again. I checked amperage draw at the switch: while pump was running and not bouncing i had 10.7 - 11 amps on each leg; when it bounces amperage was all over the place up to 28 amps on each leg when it would cycle. I have no idea what those amperage readings translate to... hopefully you guys will decipher and fill me in. After I got everything back together there wasn't enough pressure to hold the shower valve closed so i could take a shower to clean up, can't wait to get this resolved. I appreciate the help.
