Need help with shower valve cartridge replacement
Discussion in 'Shower & Bathtub Forum & Blog' started by ameneses54, Feb 26, 2013.
  1. ameneses54
    ameneses54 New Member
    Feb 26, 2013
    Orlando
    Dear contributors,
    Could anybody help me identify the manufacturer of the shower tub mixer in the photo. I'm desperate and it's leaking.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    That is a Mixet. There are 3 cartridges.... regular, pre 1968; regular, post 1968; extended length. Based on the handles, I would guess you are regular, post 68. Although Mixet is long out of business, Alsons bought up the name and most hardware and supply stores still have OEM cartridges. You should take the old one with you to be sure.
  4. ameneses54
    Feb 26, 2013
    Orlando
    Do you think the basic plumbing setup I have for this "Mixet" is compatible with some modern models from another manufacturer?
    Thank you very much.
    Arturo
  5. hj
    The "basic plumbing setup" you have is just a hot and cold water pipe, so it is compatible with ANY replacement valve you desire and can afford. IF you are asking can you convert that valve to some other design, then the answer is an emphatic NO! But there is a replacement cartridge made by No-Mix that eliminates the problems common to the Mixet one. The one question you need to answer before you start, otherwise you will probably ruin the valve body, is whether the temperature handle can rotate 360 degrees without stopping.
Similar Threads: Need help
Shower & Bathtub Forum & Blog Bathroom remodel issues, need help and advice Thursday at 5:56 PM
Shower & Bathtub Forum & Blog I need help identifying a Roman tub fixture Feb 25, 2017
Shower & Bathtub Forum & Blog Engineering students in need of help Feb 24, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
