Need Help With Shallow Well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by bigallis1, May 21, 2010.
  1. bigallis1
    bigallis1 New Member
    May 21, 2010
    Retired
    Central Florida
    Just purchased a 6 year old home in central florida that has a shallow well that is used to irrigate the lawn.
    The pump runs but it will not prime or pump water.
    I had a well contractor check it and he says the well is dried up and I need a new well dug.
    Not that I don't trust the contractor, but are there other conditions or problems that I may have and I really don't need a new well dug?
    I wanted to get feedback here before I went any further?
    Are there thing's I could check my-self, as I am pretty handy?
    The contractor did repair some of the exposed piping and could not get it to prime.
    Thank's in advance for any help or feedback.
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    The well will need to be opened up so the water level and production can be measured. Nothing is for sure until this is done.
  4. bigallis1
    May 21, 2010
    Retired
    Central Florida
    Cacher, is that something I can do fairly easy, or is power equipment needed/involved?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    I'm not familiar with how things are done in Florida. Do you know where the well is? How is it covered/sealed? There are a couple of southern drillers here who will likely reply more knowledgeably.
    I've not dealt with a shallow well before. On a deep well there is enough room in the casing to drop a string line down it to measure the water level vs. depth of the well. On a shallow well I suppose it would be best to pull the well seal and piping out to take a measurement. If the water level is below 27 feet your pump will probably not be able to pull any water from it.
    Meanwhile, if you can post a picture of the well head and equipment it might be helpful.
Similar Threads: Need Help
Pumps and Tanks Well Forum & Blog. Water is life. Need help ID'ing the well/casing Please! Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well problems - need help! Dec 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help With Pressure Tank Selection Needed....Please Dec 1, 2016
Pumps and Tanks Well Forum & Blog. Water is life. New and Need some Well help Nov 4, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Need help with well and pressure tank hook up Oct 2, 2016
