I built an RO system that is making 3000 GPD of Clean water. I am trying to incorporate a low pressure and high pressure cut off so I don't burn the pump by running it dry. So the low pressure will satisfy a possible scenario where i loose incoming water to the pump. The pump will run at 120-140 psi and looking to cut off pressure for example at 150 psi.
I found a video on youube depicting what i want to accomplish. Just need to confirm the model # for hte low pressure side. I have found this one from Sqaure D part # FSG2J20M4BP now looking for help on the high side if this one is correct.
This is the video depicting what i am trying to accomplish.
Thanks
Thanks
