I have read many great posts here on overflow gaskets. Unfortunately, I cannot get mine to stop leaking heavily into the room below. I have an access panel behind the tub and a nice big hole in the ceiling beneath the tub for several months, so I can see what's going on. It started when I was adjusting the drain lever and noticed the overflow gasket was old and torn. It was the nonbeveled type often featured in the diagrams. I tried to replace it with the beveled type and that created a loose connection /uncovered a piping issue and a pro was brought in who cut the big hole to repair the pipes and install a new nonbeveled gasket.
I don't know if our overflow always leaked (we've had the house a few years now and out three year old started more independently bathing recently) or if the hole in the hole made the leak more visible, but we get a lot of water leaking from the overflow due to random splashing or movement in the tub, even when the water is several inches below the overflow (this is a shallow metal tub).
Another plumber verified the gasket was installed correctly and it's tight, but when we tested, the water still pours through. Hundreds of dollars later, the suggestion is to not let our kid move too much in the tub and only fill it about 8-10 inches. Not an option. Also, I found that when I use the tub, even carefully, water still gets through. We even tried the "ultimate overflow" gasket with no luck. I'm desperate. I want the leak gone, to use the tub freely, and to seal the hole in the ceiling below.
Any ideas?
Also to add insult to injury, the plumbers never adjusted the lever drain (the original issue), so we have to use rubber plugs that slowly let the water out. The waste plug assembly is well attached, so I can't even remove it to replace it with a twist up (and I'm really afraid if additional leaks). (Sigh) Please help!
Any ideas?
