Need help with Fleck 7000SXT programing
Discussion in 'Water Softener Forum, Questions and Answers' started by cleverchimp, May 25, 2014.
  1. cleverchimp
    cleverchimp New Member
    May 25, 2014
    CA
    I just installed the fleck 7000SXT softener and need help with programming it (48k capacity, 1.5cu ft). Based on 3 person@60 gallon, 16-17GPG hardness, assuming 3000k/day, in 8 days that come up to 24k grain.
    I did some research and came up with this :
    DF: GAL
    VT: dF2b
    CT: Fd (Meter Flow Delayed)
    C: 24k (capacity)
    H: 17 (hardness)
    RS: SF (Percentage Safety Factor)
    SF: 20 percent
    DO: 9 (Day override)
    RT: 2:45AM
    B1: 10 mins (back wash)
    BD: 60 mins (brine draw)
    B2: 5 (salt time setting)
    RR: 10 mins (rapid rinse)
    BF: 12
    FM: t1.2 - 1.5'' Turbine Meter (7000 default)
    Questions :
    The first time the system started, I did not pot water on the tank or the brine tank. Just add gravel, resin and the salt on brine tank. The faucet inside turn yellowish (seems to be resin bleeding to the pipe), now it's cleared up. Will I have issues in the future?
    Since it seems that i loose some resin in the beginning, how to tell if I have 1.5 cu feet resin from looking at the level of the resin on the tank (the height of the resin)? (Mind you, I did have gravel before the resin).
    GPG varies between taps, sometimes it's 16 on this tap, and 17 on the others. Should I use 16 or 17?
    Are the setting right? Please advise.
  2. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    I suggest BF=6 if your BLFC is the 0.5 gpm but 12 if BLFC is 0.25 gpm. That is 6 lb/ft[sup]3[/sup].
    Make C = 30 k capacity.
    You can raise DO if you don't have significant iron.
  4. cleverchimp
    May 25, 2014
    CA
    My BLFC is 0.125 GPM actually. What is the recommended BF? I believe the default is 15, and please explain about the capacity...Gary calculator suggesting its 24K, I'm confused.
    The default setting on RS is RC, people have been suggesting RS, 20%. Do you know why?
    Also I read that if DO is more then 7-8 days is no good, while some said on city water 10 is the good setting. I'm on city water, so I'm basically splitting the difference and come up with 9 days. How many days you suggest?
    When I change the C from the default 30K to 24K decrease the remaining gallon from 2000 something to 1000 something.
  5. Reach4
    Sep 25, 2013
    Are you sure you have a BLFC= 0.125 GPM? Is there a label, or what? huge4.jpg
    See table at the bottom of http://www.qualitywaterassociates.com/softeners/sizingchart.htm
    You have 1.5 cubic feet of resin. Does calculator differ?
    At 6 lb/ft[sup]3[/sup] you need 9 pounds of salt. You need 3 gallons of water to give 9 pounds. You need 24 minutes @0.125 GPM to get 3 gallons.
    Are you talking about what was in the Fleck 7000 before any programming, or after it was set up by your dealer? The initial setting from the firmware is not shown in the service manual, and it certainly should not be just left alone. Plus, I'll bet that a lot more Fleck 7000 SXTs ship with 0.5 BLFC than 0.125 GPM. If by the dealer, remember the dealer is selling the unit by stated capacity rather than touting salt efficiency, but in that case, maybe he put in the 0.125 BLFC by mistake.
    Reserve capacity is to allow capacity to remain to handle the load until the next time it is 2:45 AM. With a longer
    My understanding is that iron removal is the reason to hold it to about a week. The question for DO is that if you are away for a week or 2, how often do you want to regen? If you use the amount of water that you calculate, then DO should not play a part.
    I might choose 14 or 20 days without iron or manganese. Some city water has those things. I am no expert. I have been reading the same things as you, but maybe just a little longer.
    You might want to get a hardness test kit. See if you are over-stretching maybe. The Hach 5-B is well respected and easy enough to operate. It is a lot more accurate than the test strips.
    If you wanted a less shocking change, you would play with those settings right after a regeneration. You have some gallons already used, so changing the capacity will have a larger effect on the gallons remaining.
  6. cleverchimp
    May 25, 2014
    CA
    My mistake, I guess my calculation is wrong. My water varies from 15 to 20 GPG, I guess I have to assume the worst water...which is 20 GPG. At usage of 180 gallons/day, that requires 3600 grains removal. Using C : 30k, that means 8.3 days between regeneration, make it 8 days.
    My resin is 10% Crosslink (made in China though), on that chart...I saw that 1.5 cuft at 30k setting only require 6lb/salt. This require 2 Gallons of water, meaning at 0.125 I need to set BF at 16.
    I'm talking the one that was set by the dealer. Sounds like a good idea, the kit rather expensive though...$40, does the Hach SofChek Water Quality Test Strips for Total Hardness, 0-425 mg/L will be good enough
    I have a revised settings
    DF: GAL
    VT: dF2b
    C: 36k (capacity)
    H: 20 (hardness)
    SF: 20 percent
    RT: 2:45AM
    BF: 32
    This setting might be more efficient in salt usage. At 30k, 1.5 cu feet consumes 6lb of salt, which need 2 gallon of water on brine tank. It saves on average about 5 lb of salt every month compared to 36k, at 10 days between regen.
  7. Reach4
    Sep 25, 2013
    OK on the BLFC. Remember DO does not come into play if the water use is what you forecast. It only maters if you use less water than planned.
    You are planning to use 4 pounds of salt per cubic foot of resin. There are people who recommend that. Gary is not one of them. But if you do use the 4, you need to reduce C. I don't have a number to suggest for C with your 4 pounds per cubic foot.
    Also note that the softener does not stop softening at some point. It just lets more and more hardness leak through with each gallon. A little hardness coming through is not terrible.
    Regarding the Hach 4B, the manufacturer's web site has a good price (surprise!). But shipping will eat up the saving unless you are ordering something else. Do you have a friend who wants a test kit also?
  8. cleverchimp
    May 25, 2014
    CA
    Right. I actually planned to use 8 pound per cubic foot, so 1.5 cubic foot that would take 12 pound of salt which translate to 4 gallon of water needed on the brine tank, with BLFC of 0.125, that takes 32 minutes.
    They dont use softener...they think it's too expensive, I think its a good investment considering all the stuff it protects...including your skin and hair LOL.
  9. ditttohead
    Jan 9, 2012
    Ontario California
  10. cleverchimp
    May 25, 2014
    CA
    This is almost the same setting as the one that I come up with, except the DO, B1 and RS. RS were set CR (This is the part that I kind of confuse, many said RS and some said CR, not sure which one is better...my understanding is, they just a reserve and calculated differently), B1 is 5 minutes? Is it long enough? DO 14, doesn't it's too long? Unless under an assumption it use american/germany made resin.
  11. Reach4
    Sep 25, 2013
    SF (Safety Factor %): Percentage of of gallon remaining capacity
    RC (Fixed Reserve Capacity): Fixed Gallon Amount
    CR (Variable Reserve): Refill amount based on grain capacity and remaining gallons in reserve when unit regenerates I was wrong. This choice selects the reserve based on recent experience.
    Do you have the service manual?
  12. cleverchimp
    May 25, 2014
    CA
    yes I do, I guess my question is why more people more toward setting it to SF. Some suggest 10%, most suggest 20%.
  13. ditttohead
    Jan 9, 2012
    Ontario California
    Use CR, it is not that critical
    DO of 14 does not matter on municipal supplies. Considering that the vast majority of systems (5600 Econominder) have an unlimited DO. It is not uncommon for systems in low use applications to only regenerate once a month. A few people dwell on the DO, again, it is not important, 14-30 is fine.
    B1 5 minutes is fine for clean water. Most "ultra water efficient" units have a 1 minute or no BW. Upflow systems also have no pre backwash. In clean water supplies, it is a non critical function. Set it for 5 -10 and you will be fine.
Similar Threads: Need help
Water Softener Forum, Questions and Answers Need help sizing katalox filter Dec 12, 2016
Water Softener Forum, Questions and Answers Need help with water softener or sanitizer Nov 4, 2016
Water Softener Forum, Questions and Answers Need help choosing best solution to filter water Sep 24, 2016
Water Softener Forum, Questions and Answers Softener Newbie needs help Sep 19, 2016
Water Softener Forum, Questions and Answers Need help to decide between WS1 or 2510SXT Sep 14, 2016
