Need help with Culligan filter system part
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DC76, May 25, 2008.
  1. DC76
    DC76 New Member
    May 25, 2008
    Washington, DC
    I’m trying to install a Culligan undersink water filter (EZ-4 model), but the supply adaptor piece just broke, and I need to get another one.
    The piece is a white plastic adaptor that the instructions refer to as the supply adaptor. A picture is here:
    http://www.flickr.com/photos/10023499@N04/2521952297/
    Is there another name for this piece, and can I find it at a hardware store? I’d like to get a metal one, if it exists.
  2. Lancaster
    Lancaster New Member
    Nov 7, 2005
    Well,its a tee,but a very specific,dedicated use type of tee.You wouldnt find one in a hardware store or even a plumbing house.You need to get it from Culligan.
  4. jimbo
    jimbo Plumber
    It looks like a Tee that would connect to your water supply valve, to tap off a supply to the filter. In the first place, I would not use a plastic piece for that. Too much downside. First, determine the size of the outlet of your supply stop, then go to the plumbing store or hardware store and get an appropriate brass tee.
  5. Lancaster
    Nov 7, 2005
    I checked out the instructions for this thing,and the tee is 1/2" pipe thread so it can screw onto the faucet shank.The other end is 1/2" male pipe,you put the faucet riser on there.So you could duplicate that with a 1/2" brass tee with a short nipple.
    But the branch outlet to the filter supply is a quick-connect push fitting,you wont be able to duplicate that.Since the supply tubing is 1/4" OD,I suggest a 1/2" male pipe thread x 1/4 OD compression adapter.You end up with a big clunky tee but should be plenty room under a sink.You do lose the convenience of the quick-connect but thats not too big a deal.Might have to do a little traveling to find that compression adapter.
  6. jimbo
    jimbo Plumber
    I still think using a tee down at the shut off valve is easier. But all you need to do is take all your stuff into a plumbing or hardware store....they should fix you up with some parts which go together.
Similar Threads: Need help
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
