Need help with crane single-handle bathtub faucet
Discussion in 'Shower & Bathtub Forum & Blog' started by dsiewert, Dec 6, 2008.
  1. dsiewert
    dsiewert New Member
    Dec 6, 2008
    I have a crane bathtub faucet, I believe originally installed in 1964. It has developed a minor leak and I wanted to dis-assemble it as the first step in a repair.
    The unit is a single handle faucet. The unit pulls out to turn the water flow on and rotates left and right to control the temperature. I pulled the little metal cap off the center of the round flow control. A bolt was now visible which holds the control knob onto the valve stem. The odd thing is that inserted through the middle of the securing bolt was a very small allen wrench. I haven't seen this before and I don't know its function.
    Removing the control handle and a chromed sleeve which covered the valve assembly, I could now see the exterior of the valve assembly. Sliding down through exterior of the exterior bronze assembly shell is a little lock-key which I assume keeps the valve in place when water pressure is applied. The two legs of the key slip between two tabs on the faucet value itself which would prevent it from rotating.
    So I removed the lock-key. When the allen wrench is inserted into the center of the value, it engages something but will only turn about a turn and a half.
    Can anyone tell me how I go about pulling the valve? Not having experience with this unit, I didn't want damage anything by applying excessive force.
    Thanks in advance.
  2. jimbo
    jimbo Plumber
    Picture please! This sounds like a Moen valve. Are you sure it is Crane?
  4. hj
    crane
    Crane used the Moen valve for a long time. The allen wrench was a "lubricator". You turned the wrench a couple of times to inject grease into the stem and keep it working. (that feature did not last very long because it did not work) You need a Moen 1200 or 1225 stem to repair it.
  5. jimbo
    jimbo Plumber
    Wow, learned something today. Never knew about this. Was it back when the valve was "stanadyne"??
  6. dsiewert
    dsiewert New Member
    Dec 6, 2008
    This explains the lavender grease I found on the tip of the valve stem.
    I found Moen has a nice on-line documentation that describes the tear-down process. Looks like I just have to pull harder to get the valve out.
    Thanks for the info.
  7. hj
    Moen
    No, when the valve was a Moen Dialcet. Although the C-2426 pressure balanced could have been a Moen Pressuretrol.
Similar Threads: Need help
Shower & Bathtub Forum & Blog Engineering students in need of help Today at 8:33 AM
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Remodeling Shower - Need help with shower drain Dec 2, 2016
Shower & Bathtub Forum & Blog Need Help identify in order to replace Thanks! Oct 6, 2016
