Need help with Carrier Furnace and LP connection
Discussion in 'HVAC Heating & Cooling' started by dcorazal, Sep 15, 2011.
  1. dcorazal
    dcorazal New Member
    Jul 19, 2011
    Minnesota
    I connected up the wiring from the thermostat and powered up the furnace. Taped interlock switch for the front panel. After studying the wiring diagram I realized that part of the LP conversion kit there is pressure switch added to the furnace so it won't turn on with no gas pressure. I connected up my 20lb gas tank to the furnace to see if it would start and it did.
    I only momentarily let the furnace run not knowing if the gas pressure from a 20 lb gas tank would have enough gas pressure (or to little) to fire the furnace.
    Question: For testing purposes-- can I run the furnace on a 20lb tank? Should I have a regulator on it?
  2. jadnashua
    I think (but am not sure) that you can or maybe already have damaged things in the furnace without having a pressure regulator in line. Now, the furnace itself may have a secondary one and you may be lucky. Typically, there's a regulator on the LP tank before it feeds anything. WIth a bare 20# tank, that is missing.
Similar Threads: Need help
HVAC Heating & Cooling nordyne air handler.need help wiring it Aug 30, 2015
HVAC Heating & Cooling r22 for central air need help Aug 16, 2015
HVAC Heating & Cooling Need Blower Design Help for Wood-Burning Stove Dec 20, 2014
HVAC Heating & Cooling terms in a hot water heating system and help needed on wiring Nov 6, 2014
HVAC Heating & Cooling Need help on which air conditioning system to install Mar 31, 2014
