Need Help with Basement Bathroom Drain/Vent
Joe F
Maryland
I am looking to install a half bath in my basement where there is already a laundry room there. The main sewer stack comes down from the above floors all the way down to the basement floor and exits horizontally out of the foundation. The laundry drain trap is 2 feet away from the main stack and drains directly into it without an individual vent. Since the stack does not go under ground, my only option is to install an up-flush toilet (like a Saniflo).
The problem I have is there is no vent stack accessible in the basement and I do not want to tear down the walls/floor in the upper levels to run a new vent stack up to the roof. I was looking up ideas and came across this photo of someone plumbing an up-flush toilet in the following manner. Is this acceptable for coding purposes? They have basically used the main sewer stack as a vent / drain for the toilet pump. My situation is almost exactly the same as this one. Thanks.
A waste line from the second floor stays a waste line all the way down.
A vent line from the first floor stays a vent line all the way up through the roof.
A lav is vented from the top of the trap arm, not below it.
Sometimes what I will do is open a wall on the next floor up and tie the vent in there, six inches above the flood level of those fixtures, normally that means 42" above the 2nd floor.
Jimbo241
Coatesville, PA
Makes sense thank you. Unfortunately for me I live in a condo unit where I own the first and the third floor, odd I know but it really is screwing with me on how to vent this saniflo plus system. I would love to just use an AAV and call it a day but I read somewhere that they won’t work on saniflo systems because they need air to go in and out. Am I just out of luck with adding a half bath on the ground level?
Jimbo241
Coatesville, PA
I’m guessing by no response that I am screwed lol but if you know of a way to save the day I would be forever not worthy but either way thanks for the info you Previously provided Me
dont you have any plumbing on the first floor? your washing machine needs a vent . This sounds like a legal issue 2nd floor owner might let you tie in to a vent.
did you bootleg a washing machine hook up? or buy it that way? How can you ever sell this place?
Jimbo241
Coatesville, PA
My washing machine is on the 3rd floor main living area (beds, baths, washing machine and kitchen) the first floor is just has what called a great room, steps leading the the main living area aka 3rd floor, access to soil stack and main water line in, and front door accesss and garage access
ok im totaly confused I thought a guy named Joe f from maryland has a problem with plumbing in basement now i see Jimbo from PA?
Jimbo241
Coatesville, PA
Yea new guy (me, Jimbo241) but we both have the same issue. I have access to run 1” drain waste pipe into my soil stack no prob there but I originally planned to run my 1.5” vent pipe from the Saniplus unit into the soil stack above where the new saniflo drain pipe would also enter into my soil stack. But terry said that wouldn’t pass code and I have to access to a vent pipe and now I’m hoping someone on here has the plumbing knowledge to help me with a fix to my problem other then running a new vent pipe all the way up to and thru the roof
Jimbo241
Coatesville, PA
So what do you guys think? Am I screwed and only left with the option of sending a new vent pipe all the way out the roof?
Jimbo241
Coatesville, PA
You can try an AAV on that and see if that works.
Air Admittance Valve.
Not sure if these photos help show my drain and vent runs coming off of the saniflo pumping up. But you make a good point there’s no reason why I can put an AAV on the vent pipe and test it to see if that will work before I start to dry wall and finish everything.
Jimbo241
Coatesville, PA
So is AAV my only option? If so how does that look? Does I need one Above on the p trap for The sink and one on the vent for the pump?
