Need help with a flange spacer.
Discussion in 'Toilet Forum discussions' started by ario, Dec 3, 2005.
  1. ario
    ario New Member
    Sep 29, 2004
    The original plumbing was done in 1922. It's a cast iron flange set in a bed of mortar on top of pine flooring; 14" offset. I installed 3/4 plywood and then tile. Now the flange sits 1/4" below the surface in the front and 3/8" below the surface in the rear. A local plumber wanted $900 to tear it out and redo properly in PVC. I would like to use a spacer of some kind if possible? I know there are PVC spacers, but shouldn't I use some kind of gasket? Is there going to be an issue with the tilt of the flange? How much of a spacer do I need? Thanks in advance!!
    [​IMG]
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    ario,
    You can use a flange extension made for the purpose and one wax ring, or double up two wax rings, one with a plastic horn on top down into the plain wax ring on the bottom. The wax ring(s) will fill the unlevel void and level out on their own between the flange and the toilet base.
    The toilet should be leveled with beveled plastic shims made for the purpose if necessary.
    However, THAT isn't your main problem. Installing tile directly onto wood (plywood or planks) will only result in cracked grout and tile due to the shrinking and swelling of the wood.
    The tile should have been installed on cement board screwed to the plywood.
    You're going to eventually have to rip all the tile out and do it right. When to do that is your call.
    Good luck!
    Mike
Similar Threads: Need help
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Need help with lose refill hose Oct 31, 2016
Toilet Forum discussions Very old American Standard Cadet Model F4049-16- need some help please Sep 25, 2016
Toilet Forum discussions Need help w/ Kohler toilet, please! Aug 2, 2016
Toilet Forum discussions Need help with new toilet decision.... Aug 1, 2016
