glazeddonut
I got this water softener back in 2008. A local company set it up and right away I was running out of soft water. It would recharge and I would eventually have soft water again, but then run out.
I called the company few times and they came out and adjusted settings each time, but I never knew what they did. Eventually it seemed to be working correctly.
Recently I had a problem where some of the resin was coming out into the discharge sink. A guy came out and replaced a part and that took care of the problem. However, when he was here he said my settings were wrong and it wasn't set up to run efficiently. When he was here I had forgotten about the problems we had back in 2008 so I never mentioned anything to the guy. He changed settings so it would only recharge when we had used the correct amount of water.
Well after about a week or 10 days or so I was running out of soft water again, just like back in 2008. I don't understand how this thing works, so I know just enough to really screw things up. I went down and added a SF of 10, but I still ran out of soft water again.
So can someone help me understand what my correct settings should be? I will give all the info I know about my softener, but if you need more info please ask.
Flex 5600sxt digital, I think 28k
.50 gpm and 1.5lb
Flow rate 11.9
Here are all the internal settings:
DF - gal
VT - st1b
CT - fd
NT - 1
C - 28
H - 28
RS - SF
SF - 10
DO - off
RT - 2:00
BW - 12
BD - 60
RR - 10
BF - 7
FM - t0.7
Let me know what other info you need and I will get it to you. Also we are a family of 4 and I assume we use the normal amount of water, but there are 2 teenagers in the house who take long showers sometimes, so not sure if that will make a difference.
.50 gpm and 1.5lb
Flow rate 11.9
DF - gal
VT - st1b
CT - fd
NT - 1
C - 28
H - 28
RS - SF
SF - 10
DO - off
RT - 2:00
BW - 12
BD - 60
RR - 10
BF - 7
FM - t0.7
