Need help today
Discussion in 'Shower & Bathtub Forum & Blog' started by edlentz, May 26, 2008.
  1. edlentz
    edlentz New Member
    May 26, 2008
    Michigan
    We are in the midst of creating a bathroom where there wasn't one. I have had my inspections and that is finaled. I am having a problem with my American Standard Cadet 3 handle faucet. The tub fill drips. The 1/2 copper pipe that feeds it is about 16" long. My problem is that we want to get the backer board up and start tiling. Is this a known problem with AS faucets? Should I go out and get a Moen, Kohler, etc...
    Thanks for any and all help.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Normally you would not have the spout itself in place. You would have a blank copper stub, or a capped threaded nipple, to stop any drips and provice something to fit the tile around. Don't try to be too cute with the fit...leave reasonable clearance around the tub nipple and the shower nipple. Spouts and escutcheons are designed to cover clearance holes.
    This three handle valve....is it new? Is is pressure balanced type??
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I'm wondering how a cadet 3 handle valve would pass inspection... Its not pressure balanced.
  5. hj
    faucet
    Probably tub only. But the valve should not drip water, unless it is just water draining from the drop pipe and valve body. If it is that water, then it will stop after a fairly short time.
Similar Threads: Need help
Shower & Bathtub Forum & Blog Need help in identifying shower faucet Thursday at 6:36 PM
Shower & Bathtub Forum & Blog Bathroom remodel issues, need help and advice Mar 16, 2017
Shower & Bathtub Forum & Blog I need help identifying a Roman tub fixture Feb 25, 2017
Shower & Bathtub Forum & Blog Engineering students in need of help Feb 24, 2017
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
