KineticoUser
- Messages
- 187
- Reaction score
- 3
- Points
- 18
I have a 1/2" copper tubing line running to my swimming pool automatic filler. Unfortunately, my tenants pushed a shovel through the line and cut it. I attempted to solder a piece of rigid 1/2" copper pipe between two ends of the tubing, but for some reason I can't get it to stop leaking. I used the standard flux I have and silver solder and a propane torch, but it didn't work. I cut it out and tried it with new pipe and fittings, with the same results. This line has constant pressure, so I need to find a way to connect the two ends with no leaks. I tried a hose with clamps, but that leaked, also. I see push-on solderless connectors, but I don't want to waste that type of money if they won't work. This is underground, so I don't care if it is connected with PVC or copper or whatever. Please help me find a solution or point out how I may have messed up with the soldering.
