Sockeyerun
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I own a small 960 sq. ft home with our own well. It has a total of 10 outlets. My questions are as follows: I have noticed the pipe banging sometimes and water pressure fluctuates quite often through the house. Upon inspecting my water system, I notice the pressure tank is leaking. So I want to change it. I don't have much info on the pump other than it's a submersible(bottom of the well) and I thinks it pumps at 6-7 gpm, All I know are the approx. dimensions of the old cast iron pressure tank 32"ht x 22"wide. My problem is that's it's under the house with only entrance in through a crawl space from the outside. So size is a definate issue or I would go by one larger than I really needed.Would a 20gallon be large enough for such a small house. Thanks ahead for any info you give. Soc
