Need help replacing bathroom sink
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by 14kbiz, Sep 10, 2013.
  1. 14kbiz
    14kbiz New Member
    Jun 30, 2013
    NJ
    I usually don't tackle plumbing jobs on my own but I'm going to try replacing my bathroom vanity. It looks like something I can handle from the research I've done. However, I noticed something a little different about how the current waste pipe is installed. Here's a picture to help explain my concern. The grey waste pipe was installed directly into to PVC going into the p-trap. You can see where the top of pvc is expanded to accept the gray pipe. What's the best to go about installing the new waste pipe into the existing p-trap? I think the new sink will be the same height as the old one. I measured from the bottom/outside of sink drain to floor and measurements are the same.
    Thanks.
  2. hj
    You throw away the gray piece AND the extension below it which is glued to it. The new drain will have its own tailpiece and you will need an "extension tube" to make it longer. The extension will probably have a slip nut on it so you will not glue the two pieces together.
  4. 14kbiz
    14kbiz New Member
    Jun 30, 2013
    NJ
    This might be a dumb question, but will the stopper assembly be in the way of the slip nut? I don't know. Just trying to analyze anything that can go wrong. That's usually my luck, it plan everything out, get so far and have a problem. I'll try the extension tube with the slip nut. Thanks for helping me out.
  5. Terry
    Aug 17, 2004
    The slip joint extension will work fine with the stopper.
  6. hj
    Do not cut the new tailpiece pipe, or at least do not cut it too short, and there will be no conflict between the pop up and the slip nut.
Similar Threads: Need help
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
