Need help Removing Stem Glacier Bay 728-075 Faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by raj49, Oct 2, 2010.
  1. raj49
    raj49 New Member
    Oct 2, 2010
    MichIgan
    I have a Glacier Bay # 728-075 faucet thats leaking. I believe its Exclusive to Home Depot. After I removed the tip, I did'nt see a set screw or any retaining screw so I can remove the handle in order to access the stem and replace the seats, spring or stem.
    How do you disassemble these?
    Any help appreciated!
    Theres no set screw or anything in there I can pry further:
  2. jimbo
    jimbo Plumber
    The barrel shaped section under the lever unscrews. originally was put on hand tight, but you might need a strap wrench to not scratch the chrome.
  4. hj
    It MAY be Glacier Bay, but it looks like a knockoff of a Moen Monticello, and if so the big "barrel" unscrews from the faucet and the handle comes up with it.
  5. raj49
    raj49 New Member
    Oct 2, 2010
    MichIgan
    So the Bigger bottom part unscrews or the part right under the lever I unscrewed?
  6. jimbo
    jimbo Plumber
  7. raj49
    raj49 New Member
    Oct 2, 2010
    MichIgan
  8. raj49
    raj49 New Member
    Oct 2, 2010
    MichIgan
  9. hj
    The HANDLE does not turn, only the "bulging" part under it. if you try to turn the handle, you will break something.
  10. raj49
    raj49 New Member
    Oct 2, 2010
    MichIgan
    Ok so this isnt Moen but Glacier Bay. The bulging barrel part turns with the handle during normal use so Im not sure about this one.
  11. jimbo
    jimbo Plumber
    It should NOT . Yours is stuck. Need to hold the lever, turn the bulge without rotating the lever.
    Glacier Bay tech support 1-888-328-2373
  12. hj
    If it does not come off that way, then the only other way would be if it had small Allen screws somewhere, and it would usually be below the handle so they did not have to make two different handles. Yours does NOT show these. Good luck with "tech support", I once ordered a faucet diverter and got two stems.l
  13. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    The handle just pulls off, try rocking it back and forth while pulling up. There will be a screw underneath holding a plastic adapter on the stem.
  14. ilya
    ilya In the Trades
    Dec 10, 2009
    home repair -I am not licensed and never represent
    Akron Ohio
    GB's tech support leaves much to be desired. I once spent 32 minutes with them before they understood that the cartridge was faulty. It took two months to get the replacement. I reccomend my clients stay away from GarBage.
Similar Threads: Need help
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
