Need help on how to remove Shower pan drain.
Discussion in 'Shower & Bathtub Forum & Blog' started by cervv, Mar 6, 2005.
  1. cervv
    cervv New Member
    Mar 6, 2005
    Automotive Interior Engineer
    Troy Michigan
    I am remodeling my Shower. Taking out the tile was easy, but I would like to take out the shower pan, but am failing to understand how the Drain was installed.
    I have removed the drain cover. The Drain has a lip that goes over the Shower Pan. In between the Drain and the 2" drain pipe I assume is Lead.
    There is now visible srews or cross pieces of metal unto which I could use to unthread by using the handles of plyers and a screw drive
    I have hit the Lead with a tool and it dents easy, but I am pushing it downward. That seems to be the wrong way.
    I have drilled holes into it. The metal climbs up the drill bit and is plyable. The hole that I leave behind is shiny. It appears about 3/8 thick minimum. I guess I could drill holes all the way around the drain, but so far I have tried 10 holes and it is taking forever.
    Does this sound like it was welded? Can this be heated and then the Drain be removed?
    The help is appreciated.
    Jay
  2. cervv
    cervv New Member
    Mar 6, 2005
    Troy Michigan
    Gotter Done
    Well. I got out the power drill instead of the cordless. After 1/2 hour of drilling I got it out. But just before I noticed I was hitting a rusty nail on one of the studs with the top of the Shower pan. I hammered it in then gave a huge pull and pulled out the pan.
    It appears the Lead was more of as space filler. So iam not sure what happened. All I am is glad it is out.
    Next problem - see you on the plumbing threads. Pipes going through studs, but no shut off to be able to cut the pipe - Darn
Similar Threads: Need help
Shower & Bathtub Forum & Blog Bathtub Drain Tie-in - Help Needed! Jan 30, 2017
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Remodeling Shower - Need help with shower drain Dec 2, 2016
Shower & Bathtub Forum & Blog Need Help identify in order to replace Thanks! Oct 6, 2016
Shower & Bathtub Forum & Blog Need help in identifying Roman tub faucet from late 1980s Oct 5, 2016
