Need Help! Most toilets dont flush properly
Discussion in 'Toilet Forum discussions' started by rjd2733, Jul 26, 2011.
  1. rjd2733
    rjd2733 New Member
    Jul 26, 2011
    NY
    Hello,
    I need some advice. I am having a problem with 2 toilets taking 2 or 3 attempts to flush before they flush the entire contents of the bowl and one that does not flush at all. I have a septic tank and my worst fear is that the tank is full. I have checked and adjusted the float in each toilet so there is enough water in the bowl, I adjusted the chain on the plungers as well. Since all 3 are having some kind of trouble my fear is the septic tank is full. Any ideas?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    We could use a bit more information. Have you check the septic tank? What kind of toilets do you have? (No, all toilets are not created equal) Have they always been a problem? Give us something to go on and maybe we can offer some suggestions.
  4. jadnashua
    A septic tank is 'normally' full (of liquids, anyway). If it fills up with solids, then you have a problem. But, if the leach field is plugged, pumping the tank won't help, as then it's time to rebuild the system and that can get costly.
    If other things drain properly (showers, washing machine, etc.), then it is unlikely to be the septic system. Builder quality toilets are not known to be very good. It may just be those toilets are dogs, and you need to bite the bullet and replace them with something that actually works. You could also have a problem with the slope of the drain lines...they must slope continuously without level sections or bellies, where they go down then back up again.
Similar Threads: Need Help
Toilet Forum discussions Need Help finding perfect toilet Jan 23, 2017
Toilet Forum discussions Need help with lose refill hose Oct 31, 2016
Toilet Forum discussions Very old American Standard Cadet Model F4049-16- need some help please Sep 25, 2016
Toilet Forum discussions Need help w/ Kohler toilet, please! Aug 2, 2016
Toilet Forum discussions Need help with new toilet decision.... Aug 1, 2016
