need help identifying faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by chucknt, Oct 25, 2011.
  1. chucknt
    chucknt New Member
    Oct 25, 2011
    Leawood KS
    We have a very leaky faucet in our kitchen sink. I have been told by the plumber that the whole thing might need to be replaced but that it is a more expensive faucet that might have a lifetime warranty. The faucet was here when we moved in so I have no idea what brand it might be so I don't know what brand of parts I will need to fix it. Please help! IMG_1016.jpg
  2. Lburk
    Lburk Technical Training Manager
    Oct 11, 2011
    Phoenix, AZ
    I believe it to be a Delta 2256. If memory serves it takes the standard Delta two handle cartridge kit with springs and seats. No big deal to fix. Check your water pressure before doing anything. Water pressure is like blood pressure, the higher it is the worse it is on your homes water system.
  4. hj
    The escutcheons, spray head, spouit, and handles are different than the 2256, so you would have to remove one of the handles and then the stem to see whose brand it is. IF he was a "halfway" competent plumber, he would know that even if it does NOT have a lifetime warranty, it can still be repaired.
  5. chucknt
    chucknt New Member
    Oct 25, 2011
    Leawood KS
    It looks a lot like the delta 2256 but is different in some ways. I can't figure out why the handles and the base would not look the exact same as the delta. I know that we have had to replace to spayed and bc they couldnt figure out the correct brand at the time, the plumber just replaced with the closest thing.
  6. BizzyBeePlumbing
    BizzyBeePlumbing New Member
    Aug 21, 2011
    Raleigh,Nc
    post a picture of the stem, turn the water off, remove the handle, remove the stem. thats a great way to identify the parts needed.
Similar Threads: need help
Plumbing Forum, Professional & DIY Advice Need help identifying this Pegasus Kitchen Faucet Feb 11, 2017
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Shower cartridge HL40, Need Help to identify this part Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Bathtub Drain Tie-In - Help Needed! Jan 30, 2017
Plumbing Forum, Professional & DIY Advice Need help with shower/tub faucet Jan 21, 2017
