Need Help Finding 0.75 mfd capacitor
Discussion in 'Electrical Forum discussion & Blog' started by SNYD, Nov 3, 2009.
  1. SNYD
    SNYD New Member
    Nov 3, 2009
    Pennsylvania
    I am in need of finding 0.75 mfd - 330 VAC capacitors. Can anyone help????
    SNYD
  2. PEW
    PEW DIY Senior Member
    I would try:
    Radio Shack
    Allied Electronics
    Mouser
    Jameco
    Allied probably being your best bet.
  4. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    I should think a higher voltage rating like 370 volts would be ok so long as it was still .75 mfd.
    So might have better luck searching for this by not including "330".
    Also capacitors are abbreviated uF
    So maybe search for
    .75uF capacitor AC
    or...
    .75uF capacitor 370 AC
    or 370 vac capacitors
    (Might call and ask some of the places you find with the last search.)
  5. jimbo
    jimbo Plumber
    Any electronic store such as the ones mentioned, or Frys, should have something. What is your application? If it is something like HVAC then a 370 VAC might be a better number. 1.414 X 240 = 339 volts!
    But if the application calls for 370, it is available I am sure. In most applications, there is no downside to using a capactor with a higher max. voltage rating.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    Depending on your application, try Grainger.
    Two 165v 1.5 uF in series will give you 0.75 uF @ 330vac [but you need some voltage sharing resistors] , or two 0.375 uF 330v in parallel will give you 0.75 uF @ 330v.
    And what's your tolerance on the 0.75?
  7. jadnashua
    The voltage rating on a capacitor is essentially its insulation rating...the point where it might short out by flashover or piercing the insulation layer. So, normally, using one with a higher voltage rating isn't an issue.
  8. Cookie
    Cookie .
    Oct 7, 2005
Similar Threads: Need Help
Electrical Forum discussion & Blog Need help wiring ceiling fan! Feb 15, 2017
Electrical Forum discussion & Blog Lost one leg of power need help. Aug 4, 2016
Electrical Forum discussion & Blog NEED HELP!!! Having problems with dryer/amps to dryer I think.... Feb 12, 2016
Electrical Forum discussion & Blog Need help with replacing these from the 70s! Oct 4, 2015
Electrical Forum discussion & Blog Mounting outdoor outlet help needed - preference between two examples shown Aug 31, 2014
