Need educational material
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Walker, Sep 9, 2007.
  1. Walker
    Walker New Member
    Sep 9, 2007
    I am putting in a 2" sandpoint well. I am down 20 feet (hit some water but not deep enough yet to pump). I need to educate myself as to the proper pump, tank, control box, hookup......before I can go further.
    Just bought a home in Idaho and doing a dozen projects before winter so have not had time to do this research. Can anyone direct me to some good sites?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    The first thing you need is a Hand Pumps.
    Once you have established how many gallons per minute your well can deliver and you find out what the water level is, you can look for a pump. I have to assume the water level is less than 25 feet in this well for using the Hand Pump. If it is not, then you will need a single pipe jet and some other items to even give it a try.
    bob...
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
  5. Walker
    Walker New Member
    Sep 9, 2007
    Thanks for the info
    Speedbump, I have a hand pump but don't think I am deep enough yet to use it. Only 2 feet of water in the pipe now... When should I try testing the flow rate?
    Mike, great site, spent half the day there.
    This is a great place to learn, I have learned more about sandpoint wells here than site on the web. Thanks
  6. speedbump
    Jul 15, 2005
    Riverview, Fl.
    If the water is less than 25 feet down, I would use it before adding each new joint. You never know.
    bob...
  7. Mike Swearingen
    Jan 12, 2005
    I have helped drive numerous shallow wells over the years. We always hand pump off the sandy, muddy water after we have finished driving the last of the "three (5') joints and a point".
    Mike
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    If you only check it at a certain depth, you must know in advance that is where the water is. Someone drilling for the first time doesn't have that luxury. This is way I recommend trying every five foot joint. If not, you may l go past the vein and not even know it's there.
    bob...
  9. Mike Swearingen
    Jan 12, 2005
    Bob's right as usual. We KNOW where our water table is here in our area, but most people won't.
    Mike
Similar Threads: Need educational
Pumps and Tanks Well Forum & Blog. Water is life. Major plumbing make over need opinions Jan 28, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Need help ID'ing the well/casing Please! Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. New Well, Need Advice on Systems Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Cup seals always need replacement after year's time. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie needs advice Cycle Stop Valve Dec 29, 2016
