need diagram for plumb on a double kitchen sink left side 10" right side 8"
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cottagepeople, Jan 21, 2007.
  1. Please help. We installed a new granite double basin kitchen sink
    The left side is deeper than the right side.
    I dont know how the plumbing should be. The way I did it , the water
    is leveling back into the sink. Can anyone send me a diagram of how it should be. We have a dish washer with air vent on top also. Here is a link for a pic of novice handywork... http://up4salebyowner.com/sink.jpg
    HELP Thanks ronandtheresa@gmail.com:confused:
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    I said it on the plumber.com and will say it here. The drain line needs to be snaked.
  4. casman
    casman New Member
    Sep 8, 2004
    New York
    Why would a new counter-top and double sink clog the drain?
  5. kordts
    Oct 15, 2005
    exurban Chicago
    Read the post. The plumbing backs up. The countertop is just fine, the countertop has nothing to do with it. The poster needs to have a plumber with the proper equipment snake the drain.
  6. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Yes. The picture shows everything fine under the sink, but the shallow side of the sink drains into the deeper one because the drainage has nowhere else to go.
  7. kordts
    Oct 15, 2005
    exurban Chicago
    lee,
    are you a plumber? The sink backs up because the drain line is clogged.
  8. leejosepho
    Nov 23, 2006
    I am an across-the-board mechanic, and it does not take a professional plumber to know the drainage has nowhere to go ... as in "the drain is clogged". I was simply using different words to confirm what you had said.
  9. Rancher
    Rancher Guest
    Yeah, needs a snake run down that convenient clean out to the left of the P-trap.
    Rancher
  10. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    And run a lot of water while pulling the snake out.
  11. leejosepho
    Nov 23, 2006
    Once flow has begun, I have heard that alternating between a few minutes of cold and then hot water can cause blockages to contract and expand and break loose from the inside walls of the pipe ... kind of like a "heat wrench" for plumbing internals. But, I do not whether that really works even though I have done it a few times.
Similar Threads: need diagram
Plumbing Forum, Professional & DIY Advice I've got some sink drainage issues; need advice/diagram to correct Jan 3, 2017
Plumbing Forum, Professional & DIY Advice rough plumbing diagram/advice needed Jan 26, 2014
Plumbing Forum, Professional & DIY Advice Need review of a rough plumbing diagram Jul 12, 2012
Plumbing Forum, Professional & DIY Advice Need advice on replacing toilet flange Mar 18, 2017
Plumbing Forum, Professional & DIY Advice Do I Need To Replace This Pipe Soon? Mar 15, 2017
