Need an answer soon
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by psal2, Sep 2, 2005.
  1. psal2
    psal2 New Member
    Aug 28, 2005
    I am cross posting this because no one seems to be looking at the other thread.
    Quote:
    Originally Posted by Terry
    I would use a mission coupling with a stainless cover over it, 2" plastic x 2" copper.
    I am new to this and sometimes a lot dense...
    3001-22 at Fernco looks like what you are talking about. This is a 2" cooper to 2" plastic Proflex coupling and looks like it has a stainless steel cover.
    HD has a Fernco 2" X 2" rubber coupling with stainless steel bands only.
    I have called 3 plumbling supply places around here and they either don't want to deal with an idiot like me or just handle contractors. And none had a Fernco or Mission coupling that was Cooper to Plastic. One said CI to PL, would that work?
    Otherwise, can you tell me where I can order one?
  2. thezster
    thezster New Member
    Jul 18, 2005
    Retired young... day trade stocks - and to keep bu
    Fort Collins, Colorado
    Do an online search for plumbing supplies/fernco. You'll find what you want. HD carries exactly the part you need - here in Colorado. You might check another box store or a HD down the road.
  4. hj
    coupling
    The CI to plastic coupling would only work if you cut a coupling in half and solder one half onto the copper prior to installing the rubber coupling. Then the o.d.'s would be acceptable.
  5. psal2
    psal2 New Member
    Aug 28, 2005
    Thanks but I promised thezster that I would stay away from the flames and sweating and soldering...
    I will check online or at HD. Appreciate the response.
  6. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    Yes, you need a 2" copper X 2" plastic sheilded coupling. The Proflex coupling (3001-22) made by Fernco would be correct. The inside diameter of the CI X Plastic coupling you asked if you could use would be FAR too big to connect to the copper as would the rubber fernco coupling with the bands you referred to. If there is a Ferguson or a Winnelson close by you, these are stock items they carry.....as I would assume would be the case and most plumbing supply houses.
  7. psal2
    psal2 New Member
    Aug 28, 2005
    No Ferguson or a Winnelson are in this area.
    I called 3 other plumbing supply places and no luck. I found a site on the internet that has them and if I don't find one locally (my HD and Lowe's don't have the 3001-22), I will just go on-line. BTW, guy at Lowes said the same thing about the OD, that appears to be the first right answer I got from a big box store in weeks...
Similar Threads: Need answer
Plumbing Forum, Professional & DIY Advice Answer: Do I need to add a vent for my shower (photo)? Mar 22, 2015
Plumbing Forum, Professional & DIY Advice Need question answered about water and pressure and cold outside (if that makes sense Jan 23, 2013
Plumbing Forum, Professional & DIY Advice Hydronic Heating question... need answer fairly soon. May 28, 2010
Plumbing Forum, Professional & DIY Advice Hey need a connection answer Feb 3, 2009
Plumbing Forum, Professional & DIY Advice Materials needed to PEX Bathroom Sunday at 10:01 AM
