Need air inlet in laundry room?
Discussion in 'Remodel Forum & Blog' started by SteveW, Mar 26, 2005.
  1. SteveW
    SteveW DIY Senior Member
    Feb 11, 2005
    Omaha, NE
    Here's a question for the group: Is it necessary to have some sort of air inlet for a laundry room, to let air in for an electric dryer?
    I have a small laundry room on the main floor of my house. I notice that when the dryer is running, and I leave the door ajar, the door is pulled into the room by the air being drawn into the dryer. It dawned on me that a clothes dryer is basically a big air pump...
    Is it OK to close the door? There is a 1-inch gap under the door, but does this compromise the efficiency of the dryer? My wife doesn't like to leave the door open, due to our dog getting into the room (and the noise).
    If we need more air flow, any creative thoughts, other than putting a grill on the door? Don't want to do that since it's right in our main hallway. Could I open up a small air vent into the ajoining closet?
    Or not worry about this?
  2. Terry
    Aug 17, 2004
    You will get more pulling power from the dryer is the room is vented.
    You can check to see how much it would help, by having someone open the door while holding your hand outside over the dryer exit.
    If there is a difference, you may want to cut through the drywall on put two grills in.
    Most laundry rooms have a heat duct that adds some "return air".
  4. SteveW
    Feb 11, 2005
    Omaha, NE
    My little laundry room is so small it doesn't have a HVAC duct of any type.
    I like the idea of checking air output with the door open and closed -- tried it and no obvious change in airflow at the outside exit. I think I'll go ahead and add a couple grills in the drywall anyway. I guess there's no reason why the two grills actually need to have a "duct" between them, is there? The stud cavity (interior wall) would be closed anyway, so I should be able to just cut drywall on both sides, screw in a grill on each side, and be done, right?
  5. jadnashua
    I think you'll find that clothes dry faster if you don't have a restriction in the air for the dryer. WIth the cost of electricity going nowhere but up, it makes sense to make it's work easier. In a REALLY tight house, exhausting a lot of air without some coming in from outside also creates problems. When the dryer is running, the air you are blowing outside has to be made up from somewhere or you'll be sucking things like exhaust fumes from the heater into the house, or cold air through the cracks in the house. Same problem with a hood vent on the stove (assuming it doesn't just recirculate the stuff after trying to filter out the grease, etc.). They make air-to-air heat exchangers for this problem - preheats or cools the air based on the season by exchanging energy in the air stream, minimizing the energy loss and providing good fresh air to the building. I read somewhere that they are required in new construction in Canada, and probably a good idea here as well. My unprofessional opinion.
  6. SteveW
    Feb 11, 2005
    Omaha, NE
    Good points, Jim. My house isn't particularly tight, but I could really see how a clothes dryer or high-efficiency fan in a range hood could cause some real problems in a tight house. I've heard before that you need air for combustion of water heaters, furnace, etc., but never thought about the effects of the various exhaust fans we have (the clothes dryer being one of them...)
    Thanks for the feedback!
  7. resq944
    resq944 New Member
    Mar 31, 2005
    Most Dryer manufacturers will mandate a certain amount of ventilation in a closed laundry room or closet. For instance my HE3 Dryer required either 24 sq" of ventilation area or a louvered door.
  8. SteveW
    Feb 11, 2005
    Omaha, NE
    Another good point. I didn't think to check out the owner's manual...
  9. copperhead
    copperhead New Member
    Apr 2, 2005
    The louvered door would probably be your best option but if you go with the two grills you can add some blocking to the top and bottom of your cavity by cutting some two bys the length you need and inserting them between the sheet rock. Screw through the sheet rock on both sides to hold it in place and then run some angled screws into the existing studs. Torx screws work well, somewhat cashy but your fingers and patience will appraeciate them.
  10. copperhead
    Apr 2, 2005
    I forgot to mention that this may help if by chance your grills develop the squeaks and rattles that gives you the sense of a trailer park!
Similar Threads: Need inlet
Remodel Forum & Blog Garage rebuild need help Nov 5, 2016
Remodel Forum & Blog Do I need to retrofit my pony wall retrofit? Jun 6, 2016
Remodel Forum & Blog Basement closet wall with foam needs drywall for fireproof? Jun 4, 2016
Remodel Forum & Blog Concrete slab woes; need new water lines, radiant heat is leaking. Apr 24, 2016
Remodel Forum & Blog Need some guidance on making a fence design a reality Jun 15, 2015
