tmy23
First thank you for any help! I am converting a small room adjacent to our master BR into a master bath. Nothing complex, 3 appliances...Toilet, Sink, Shower. Our hot water heater and cold supply are directly below the room (2 floors below) in the basement. All the other plumbing "appliances" in the house, two baths and the kitchen are at the other end of the house, 60+ ft away. I was considering running 3/4" PEX up to the new master bath to a manifold and then 1/2" runs to the three appliances. I am wondering if using 3/4 to take water off the same Hot/Cold Supply that runs that distance to the back of the house might starve those areas when both ends are demanding water. Should I instead reduce to 1/2" to supply the new master bath? The total run to the new MB is about 13' vertical and a total of 12' total lateral run, about 6 ft in the basement and 6 feet in the bathroom.
thank you for all help!!!
